Lands Phones Logo
Nancy Hill Posted on Aug 03, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I unblock a number on the Panasonic kx-tg9331?
Level 3:
  • Panasonic Master 6,688 Answers
  • Posted on Aug 03, 2017
Cindy  Wells
Panasonic Master
Level 3:
Answers
6688
Questions
0
Helped
3529825
Points
21744
You can unblock a number by entering the Menu System and then going to the block call section. The fastest way is to press Menu then press # 2 1 7 . Then use the up/down arrows to highlight the number to unblock; then press Select (if Edit/erase aren't displayed). Use the appropriate soft key to select Erase. Then select Yes and press Select. Press Off to exit the menu system. See page 28 of the manual.
Panasonic has the manual on the product support page: http://shop.panasonic.com/support-only/KX-TG9331T.html . The direct link to the manual is ftp://ftp.panasonic.com/telephone/om/kx-tg9331_en_om.pdf .
I hope this helps.
5 Related Answers
helpingout
  • Posted on Jun 17, 2008
SOURCE: panasonic cordless phone KX-TG9331, the
If you have listened to all messages on the answering machine, then this is the "tone" that the phone company sends out for those people who have paid voicemail with the carrier.
Page 41 of the manual - "if the handset still indicates there are new messages even after you ahve listened to all new messages, turn it off by pressing and holding [OFF] until the handset beeps.
Page 40 of the manual - "Turn VM tone detection on/off - the default setting is "ON" 1. [Menu], then press #332 then choose [OFF] - now when the phone company sends a tone out to your phone it will be ignored.
Anonymous
  • 5 Answers
  • Posted on Jun 02, 2009
SOURCE: Display light is on but the words don't show up.
Dear a1trkr,
Press the menu button on the handset and type in (1) (4) (5) THen press 1-6 for LCD Contrast.
Hope that works! I have a panasonic and I love the clarity and range.
Best of Luck, The Writer.
Anonymous
  • Posted on Oct 03, 2009
SOURCE: Configuring caller IDfor India
use a caller id converter..i know u get it in sp road in bangalore
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Nov 09, 2009
SOURCE: I NEED TO STORE NUMBER ON MY PANASONIC KX T7730
The mechanics of storing a speed dial number on Panasonic phones is the same, even if the phone can be connected to one of 18 different model Key Service Units. It involves pressing PROGRAM a button, an access code, the number, and STORE. In the U.S. our access code to get an outside line is "9". You may be using something different, like '0'.
The differences are if you can dial "9" on the intercom and get a dial tone, which collumn of buttons you press, and/or whether you want this to be PERSONAL numbers or SYSTEM numbers.
In a TA-824, lines are accessed high to low. If you have 2 lines on a basic system and dial "9" to get an outside line, you will land on line 3 if you have not told the system that line 3 is disabled (system program 400). So, the fast answer is press PROGRAM, a button on the right side, dial 9+your desired number and STORE. If it's a left side button, dial 29 instead of 9.
System speed dials requrie access to system program 001.
If this does not work on your system, please comment back with your actual system model number.
Carl
Anonymous
  • Posted on Feb 28, 2010
SOURCE: kx-TGA641T how does one unblock blocked number
http://ww2.justanswer.com/uploads/MCVGreg/2009-09-21_023145_KXTG9331-Remove-Blocked.pdf
Viewing/editing/erasing block call
numbers
1 {MENU} -> {#}{2}{1}{7}
2 {V}/{^}: Select the desired item.
~To exit, press {OFF}.
3 Proceed with the desired operation.
■ Erasing a number from blocked list:
{Erase} -> {Yes} -> {OFF}
you can also edit:
■ Editing a number:
{Edit} -> Edit the phone
number. -> {Save} ->{OFF}
Panasonic - KX-TGD530. How do I delete all the blocked numbers on my KX-TGD530 please?
I have a phone KX-TGD530 with call block. I accidentally
JustAnswer https://www.justanswer.com > Electronics Question
Jun 25, 2018 - I accidentally blocked a number. I have been trying to unblock the number but everything I try does not work. PLEASE. Tell me what I can do.
1 answer · Top answer: Hi, I'm Nathan. Sorry to hear that you're having trouble, but I'll do my best to help you. ...
How to remove / unblock a number from the blocked calls list.
Panasonic https://help.na.panasonic.com > answers > how-to-rem...
Follow the instructions to learn how to unblock/remove a number that you no longer want blocked. ..
Dec 09, 2023 • Cell Phones
How to unblock a blocked number on a Panasonic KX-TG1033C phone menu, then initial setting? Cant find it.
Strangely, I can't find it in the manual. The manual does have a helpline support number.
Operating Instructions
Panasonic https://help.na.panasonic.com > 2023/02 PDF Operating Instructions. Expandable Digital Cordless. Answering System with 2 Handsets. Model No. KX-TG1032C with 3 Handsets. Model No. KX-TG1033C.
48 pages
Different model but the procedure should be the same
I have a Panasonic digital cordless phone model KX-TGE210. I accidentally block a number on my phone that I need to unblock to receive calls. Can you tell me how to unblock a number?
I have similar phone.
Press Menu then enter #217 to edit blocked numbers.
Use up or down arrow to scroll through numbers.
You can erase or edit blocked numbers.
For more info, see manual at: http://www.manualslib.com/manual/754430/Panasonic-Kx-Tge210.html?page=1
I have the Panasonic KX-T7633 and when I dial a certain number is rings engaged and comes up with ACCNT - please how do I unblock this?
You don't. It's looking for an ACCOUNT number, which are assigned by the system manager. The number you have dialed is restricted by class of service. If you have a class override code, you can use that, or go to a different phone.
Dear a1trkr,
2answers
Were those other instruments purchased in India? The problem is that the U.S .uses a different"signal" to send caller ID than India.
2answers
Answering system
my answering machine light blinks but the machine isn't working.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
