Motorcycles Logo
j
john cruz Posted on Aug 03, 2017
Honda xrm 110 headlight diagram - Honda Motorcycles
3 Related Answers
sisadsl
gavin jones
  • 1508 Answers
  • Posted on Feb 25, 2011
SOURCE: while engine still heat, my
this may mean it is too rich, make sure the air filter element is new and change the oil which can get contaminated by fuel. some new spark plugs may help
There is obviously other reasons but start with these simple things.
I use an upper cylnder lubricant,and seems to help my bikes start hot and cold, dont really know why
Randy Ohler
  • 14585 Answers
  • Posted on Sep 06, 2015
SOURCE: why is it my xrm 110 is hard starting and uses many spark plugs
To much fuel being put threw the engine.
robemcdermo
Robert McDermott
  • 72 Answers
  • Posted on May 18, 2017
SOURCE: Honda XRM 125 wiring problem.
Hi, I'm a 45 yr Yamaha mechanic & take this advise or not, But if your harness is been stripped open or cut up badly, You definitely need to replace it with new from a Honda dealer. You MUST have the correct year so take the 17 digit serial number with you. It is stamp on the MAIN FRAME somewhere. You can install it, It isn't very hard to do. All the plugs have matching wires & connectors. Just look at the colors of the wires going into & out of a plug. They almost always match up. The very few that don't will have the only matching plug in that section. Then if you come to a plug or wire that you don't know, Any Honda mech. can tell you that exception. Or come back to me at that point. Don't try to wire it without a good harness, You can burn out some expensive parts if not already done.
Can you give us wiring diagram and wiring intstruction for xrm 125. Thanks
https://tops-stars.com/wiring/honda-xrm-125-wiring-diagram/attachment/honda-xrm-125-wiring-diagram-boulderrail-intended-for-honda-xrm-125-wiring-diagram/
Jan 23, 2019 • Motorcycles
4helpful
How to install hid head light on xrm 110
how to conect the HID bulb into XRM motor with daigram
Top Honda Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Honda Expert? Answer questions, earn points and help others
