Question about Jacuzzi Home
Need to know where the reset button is on Kohler jacuzzi tub
Posted by Cathy Sheppard on
Terry Weaver
    Master:
  • 412 Answers
The only place I'd expect to find a reset button is on the motor itself. That is, unless it's a ground fault problem, in which case it might be on another ground fault outlet somewhere in the house (possibly a bathroom or garage outlet) OR on the breaker - check the breaker box to see if the breaker's tripped or the GFE button needs to be reset.
Posted on Aug 03, 2017
5 Related Answers
Alan
  • 80 Answers
SOURCE: Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Posted on Sep 05, 2009
uspartscente
US Parts Center
  • 719 Answers
SOURCE: Jacuzzi tub power button not working, can hear it
that is the sounds of a bad air button on the side of the tub.
Posted on Sep 06, 2010
uspartscente
US Parts Center
  • 719 Answers
SOURCE: how to fix air button on my jacuzzi tub. when i
Air Buttons have a threaded body that has a nut on the underside of it that holds it in place. You will need to get the under the tub to get that nut off the button body to remove it and get it changed.
Posted on Jan 12, 2011
uspartscente
US Parts Center
  • 719 Answers
SOURCE: I don't see any start
Fill the tub with water. get it in. touch the Logo.
Posted on Feb 01, 2011
joeguest2
Joe2
  • 2080 Answers
SOURCE: i have a regular size bath tub with a jacuzzi with
First of all make sure you have the tub filled with water to a level above the jet inlets. They normally have a sensor to prevent the tub from starting dry.
Next, check and reset any GFCI electrical receptacles that might be on the same circuit as the tub. They are the wall receptacles that have the 2 little buttons in the middle. Look in the bathroon, adjacent bedroom, closets etc.
The only other thing you can really check on your own is the air tube leading to that metal switch on your tub. The switch is not electrical for safety, it is a little air pumper with a plastic hose attached to it leading to an air powered actuator on the pump. Sometimes the hose dries up / comes loose / falls off. Check if there is an access panel on the tub where you can look inside and see if the plastic hose is still attached at both ends. You might even be able to unscrew the metal switch cover and lift it up and see from there. Otherwise try fpumping the metal switch (firm repeated pushing) to see if that will activate the pump. If that does the trick then it is probably just a loose connection / leak on the air hose such that it is not quite airtight.
Good luck and please comment back if this was at all helpful or if you need further assistance.
Thanks.
Joe.
Posted on Feb 13, 2011
Kohler led lighting and jacuzzi motor + jets stopped working but automatic line clearing air still blows when tub is emptied.
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
Oct 06, 2013 | Kohler Home
Leaking jacuzzi jet
The workings of a bath jet...From the inside of the Bath there is a wall fitting that threads from the inside of the tub into the jet body located on the outside wall of the tub.
If the jet is leaking at this point behind the tub then you should take the wall fitting out of the tub and put a small bead of 100% RTV silicone around the flange of the wall fitting and reinstall it.
If however, the leak is from the PVC piping going into the jet then you will need to replace the jet.
Rod
US Parts Center
888-521-6183
Jan 14, 2013 | Kohler Home
Hytec Kohler Model LM34520 air jet swtich not working. 4 years old and last use, the push button stopped working. Cannot see connection detail at switch/button end but disconnected at motor and and can...
The problem you are experiencing tells me that the air switch in the motor most likely the problem.
This is a latching air switch that operates when the button on the side of the tub is pushed.
The replacement TBS-339 air switch is around $21
Rod
US Parts Center
Jan 06, 2013 | Jacuzzi Home
I have a kohler jacuzzi tub and many times over the past 5yrs the pump continously trips and the jacuzzi will not start. Any suggestions i have tried to reset the button unplug and plug it, an filled it...
Sound like your pump may have a leak into the electric motor part of it through the shaft seal.
Or it could just have junk stopping up the lines or the pumps impeller. Hair often finds it's way into these things and screws them up!
If it's leaking there will be some water showing below the pump unit.....
Feb 20, 2011 | Kohler Home
My jacuzzi tub will not come on . fist it was making a humming sound , i turned it off checked the reset plug tried to turn it on and not a sound
mine did the same thing. the tub is plugged into a ground fault interupter (gfi) plug. hit the reset button. if this doesn't work, check the circuit the gfi is on, sometimes they are on the same circuit as the plugs at the sink. check them for reset also. if this fails, on the motor of the tub, there should be a reset button. try to reset it. OH first make sure the breaker has not been tripped.
Jan 04, 2011 | Jacuzzi 4481-959 Nova 5 Soaking Bath 5'-...
Kohler Whirlpool tub motor wont turn on
Kohler Whirlpool tub turns on and shuts right off. Reset gfi and motor turns on and shuts right off. Help
Mar 15, 2009 | Kitchen Appliances - Others
Home Logo
1,208 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
