Computers & Internet Logo
a
arden curts Posted on Aug 02, 2017
My traigle palm turns brown and bows die. what should i do?
1helpful
Cat paw palm tree tips of leaves turn brown, how to prevent?
Soil PH sounds a bit high - that will cause browning - you want your soil PH to be around 6.5 for good green cover
May 04, 2017 • Garden
Draw length adjustment on an old browning explorer 2 compound bow serial number y1b 3995
hard question lots of explorer 1 s
just pulleys and bow string
explorer two same system
if a 1960s bow 47 inch tall 55- 70 pounds approx
Sep 17, 2016 • Optics
Why can I pull out brown fronds by my hands on my sago palm's trunk?
Usually once every year or two, Sago Palms bottom frond will die off in order to produce new ones that shoot out the top. Once they die you can pull them out with your hand because the fibers that attach them are also dead.
Clumping palms are dying
check you soil ph sometimes the soil Ph can change. and can cause this. also try some plant food in water. out side plants sometimes need some food over the cold months. also if it gets to cold for to long it can kill the plant off.
Draw weight reduction ifo for browning pro hunter 11 comoud bow
Never back off the limb pocket bolts more than 3 turns or it may come apart. Check your users manual for max turn out. Always to be sure you back out each bolt equally or your timing will be off. If you think you made a mistake tighten both bolts all the way in and start over. I repair Archery equipment in northwest Indiana. The Archery Clinic
Nov 29, 2013 • Archery
My palm tree appears to have died following a recent cold spell. the leaves have turned brown and are falling off. is there anything i can do to save the tree?
Unfortunately,no not at this point.You will have to replace them.Next year use 1x2 stakes and build a frame to fit around and over the trees.Staple CLEAR pe tarp and you have an instant temporary green house.A roll of 100yards by 20 feet at Lowe`s is about 80usd,and can be reused.
May 13, 2011 • Garden
Hi there, we have recently moved house, the palm tree (according to the previous owners has been there over 16 years planted by themselves). The tree has been shedding its leaves over the winter months,...
Hello Eileen, W/D here.
Palms will reabsorb some of their nutrients when fronds are shed, even over winter. If possible, you should let the ugly fronds go, and allow the trunk to take back what's stored in the frond stems. When they become brown, or less green, or droop, they can be pruned. This is usually found with the lower fronds. If upper fronds exhibit these symptoms, it is usually from the effects of winter, but the same rules apply, except that you can trim partial fronds to get rid of the brown leaves.
The acid test for a palm is, if there are shoots in the middle of the canopy protruding, to pull on them firmly, but not aggressively. If the shoots pull out easily, the palm is probably dead. Some winters are more brutal than others, and palms take the worst of them. We double-cover our palms, and place lights inside of the covering that we make, and the larger ones have made it over winter now for about 5 years. I have used incandescent Christmas lights wrapped around the trunk and hung in the canopies, then covered and it worked well too. One friend slaved his Christmas lights to his pool pump control panel, only to lose his palms. Seems that he was using LED lights, which put out no heat. Queen palms have died in droves this, and last year, as have unprotected Robellinis. Washingtonians and Pindos have fared better. If you live in a coastal zone, you still need to cover and keep your palms warm through the worst of winter. We have used fitted sheets on the smaller canopies to contain the fronds, then covered that with plastic tarps, weighted down on the sides to form a mini greenhouse, and it works pretty well, but it's inconvenient. With spring here, there will be a lot of new outdoor umbrellas purchased, and the old ones will be pitched. We already have picked one up from a neighbor, and will erect it over one of the palms, then cover it as described. The thinking here that it should be much easier (and quicker) to protect the palms via this method.
As for the fungus noted, try light applications of a fungicide, but check first with a local nurseryman to see what works best in your area.
Hope that this is of some help.
Best regards, (and please rate this solution), --W/D--
1helpful
Palm turns on but will not operate programs
You need to perform hard reset by pressing reset and power button same time.
Top Palm Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
