SOURCE: I wish to scan a
Welcome to Fixya
Your printer usually came with a software disk wherein you will install it in your computer. Inside this disk are the softwares of your computer and they are drivers of the printer, software of the printer for imaging, scanning and faxing software. I suggest you look for the disk and install all the software inside the disk.
Let me know if you have further questions.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: cannon scanner pixma s it's not scanning
TRy checking your cable between the scanner and computer. If you have spare try changin wire, it could be a problem with the wire or connection is not good.
SOURCE: I have a Cannon Pixma
lift the lid on your scanner lay the photo face down then select scan
document/photo it will ask what format you want to scan it then it will ask
where you want to save it browse select the file/folder where you want to save
it (my pictures) most common hope this
helps
you can send an
attachment to a company by an email
open up your new email type
in the adress then you should see attachment depending on which email you are
using select attachment then you will open up a browse window navigate to
your document/attachment select it you might have to wait a few seconds for it
to load as an attachment then click send
SOURCE: How do I scan a document with Canon MG2520?
When you installed the machine on your computer, assuming you did a standardinstallation the scanner driver and software should also have been installed. Assuming you are using a Microsoft environment ie Windoze something, you can check your scanners and cameras folder. The MG2520 should be listed in that folder. If not - re-install it. Then go to this page:
http://ugp01.c-ij.com/ij/webmanual/Manual/M/MG2500%20series/EN/CNT/cnt_scan.html
