I have a Fedders Dehumidifier. It is wired under the house with a drain hose which is great However since it is hard to get to in the crawlspace, I need a remote that will turn it back on when the power goes off rather than crawling under the house to manually do so. Do you have one I can buy?
SOURCE: Connecting a drain hose
Most units have a drain connection, either on the machine itself, or in the collection pail. These connections usually fit standard garden hoses.
SOURCE: Fedders Dehumidifier - Wont Turn On
Looks like a control board, Check the board for burn marks. What model do you have? Some parts are available on-line at appliance factory parts.. also check your Capacitor and fan motor before you install your new Board..Let me know if this helps? Krazytech
SOURCE: Connecting drain hose to the Dehumidifier
If you go to this site you can download the owners manual. Follow the instructions and it should solve your problem.
http://136.166.4.200/contents/Dehumidifiers/DH30.htm
Sgt 48
SOURCE: Fedders 65 Pint Dehumidifier Fan Problem
I have the same problem. The fan motor bearings are bad on mine. You can get a new fan motor at Appliance Factory parts.com. Phone number 1-800-955-7075. $44.95 + shipping.
Gene
