Question about Boating
1967 fiberform boat manual - Boating
Posted by Tommy on
Kardoc
    Top Expert:
  • Boating Master
  • 5,898 Answers
What year is my sea king 9.2 motor. And who made it. Model #VWB 29909A, serial number 96x10236
Best I can find on a Sea King 9.2 hp. After 1964 it was built by Chrysler out board. The 9.2 was only in the years of 1966-1967. Hope this helps.
Jan 16, 2017 | Boating
In my 1980 Fiberform, I have no power to any accessories or to my ignition, and my battery seems to have a full charge.
Check battery connections. Check voltage at fuse panel. Should have same voltage as battery. If voltage is present turn on any switch, if voltage goes away with a load follow the no voltage procedure but leave the switch on while testing.
If no voltage, check for any fuses or circuit breakers in the supply wires. Still no voltage: connect voltmeter red lead to positive at battery, black voltmeter lead to negative at fuse panel. Voltage OK problem is with positive supply to panel. If no voltage connect meter red lead to positive at fuse panel, meter black lead to negative at battery. Voltage OK problem is with the negative supply to panel.
If fuse panel is supplied voltage from the ignition switch start the voltage tests at the ignition switch.
Sometimes the positive and negative supply for the fuse panel are connected at the engine. Usually the positive at the starter solenoid, if so use that source instead of the positive battery post. Voltage must be traced from the root source to the load. Both positive and negative must be isolated and verified separately. Without one, positive or negative, there will be no voltage at the load. The load being whatever needs voltage applied to function, (light, pump, etc.)
If there is a corroded connection or wire it is possible for voltage to pass through the corrosion with no load. When a load is applied more amperage is required. The corrosion is not a good enough conductor to carry the required amperage and the voltage goes away. This corrosion can be at a terminal connection, (wire to switch, battery cable to battery lug, battery lug to battery post, etc.), internally in a switch, wire, fuse or circuit breaker. It is possible for a wire to appear to be in good condition. The outer insulation can be intact while the inner conductor is corroded, sometimes turned to green powder. This is why marine grade wire is more expensive than standard wire. Marine grade wire is tinned copper, copper conductor electro coated with tin to resist corrosion.
Oct 05, 2013 | Spectrum Color Fiberform, 1980-1985, White...
I need to see a motor schematic for a 1967 evinrude 40hp outboard
Go to Boats.net and you should be able to look up your parts
Jul 24, 2011 | Boating
Dont know what amp to put where in my 1967 vw bug fuse box
According to the information that I have been able to find, they were all 8A fuses originally. It's never been that way in any of the VW's that I have ever owned, but here is a page from the original 1967 VW owner's manual. It shows fuse position, but only recommends that the driver carry spare 8A fuses. There is no mention of any other fuses.
Here is a link to the entire manual in PDF:
1967 VW Beetle Owner's Manual
May 10, 2011 | Volkswagen Beetle Cars & Trucks
What is the oil to gas mixture ?
buy a manual for it first as it will have all your specs and diagrams of the fuel system. clymer makes one for this motor.
Jun 16, 2010 | Boating
Rocker arm gap
That engine was used in so many different models, I would suggest you check a public library for a Chilton or perhaps even a factory manual of that era. I think there would be several possible vehicles (and manuals) that would contain the specs you need.
Most larger llibraries have them or can get them in through their system.
Jun 29, 2008 | Chrysler Aspen Cars & Trucks
Boating Logo
161 people viewed this question
Top Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
