Question about Toshiba Computers & Internet
Trying to get the back off of my Toshiba 50L1350U television in order to troubleshoot it.
Back won't come off even though all the screws are out (that I can see) and the stand is off. Seems like the only way to separate the back from the front is by prying it off...?
Posted by Neal Salesky on
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: red lines across screen
it sounds like a b+ cap going bad and is intermittant that feeds the the video drivers on the crt pcb or the crt is shorting. I have seen intermittant shorts in crt before.
Posted on Mar 28, 2006
Anonymous
SOURCE: how to get pedestal off a toshiba 32 HL 67
Take out 5 HEX head screws and one black screw from jack pack cover. the pedestal will slide out from bottom. You do not need to remove jack pack cover as it is part of entire back panel.
Posted on May 22, 2008
Steven
  • 15 Answers
SOURCE: tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Posted on Sep 06, 2008
Anonymous
SOURCE: Insignia TV stand screws
Had same problem with Insignia TV...#12 - 24 x 1/2" machine screws...found at Home Depot in bagged items (can't use longer because some of the holes don't go all the way thru)
Posted on Jun 19, 2009
Toshiba 50L1350U Tv no picture
mine had x6 swollen capisitors ,i replaced all 6..got off ebay,,and it works fine now,check them all first
Aug 12, 2018 | Toshiba Televison & Video
No back lights an black screen model 50l1350u
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Oct 29, 2015 | Toshiba Televison & Video
Getting horizontal lines on the bottom half of my toshiba 50inch led TV model#50L1350U, is there an easy way to fix this or I should I bring it in for repairs?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sep 28, 2015 | Toshiba Televison & Video
Has sound ,no backlight, faint image
If you see a faint image, backlight is there, but its intensity is less. There are many reasons for this fault. From back-light inverter board to LCD panel should be checked for the fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 19, 2015 | Toshiba 50L1350U 50" Class 1080p LED TV
TOSHIBA 50L1350U LED TV WILL NOT TURN ON
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Aug 04, 2015 | Toshiba 50L1350U 50" Class 1080p LED TV
How do you remove the back casing?
There are plastic tabs that hold the back in place in order to get the screws to align. Use a flat head screw driver or kithchen knife to pry the tabs apart and slip the cover off.
May 10, 2014 | TCL L40FHDF12TA
Hi, My dvd has got stuck in my hitachi hit19wdvbdvd player the eject button won't work.
unfortunately, if the drive is stuck, the only way to retrieve your disk would be to take the unit apart. Be careful though as this will void any warrenty. Make sure the set is switched off and unplugged before attempting this, be careful as even when switched off, some tvs can still hold a lot of voltage.
May 05, 2011 | Hitachi Televison & Video
Computers & Internet Logo
74 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
