What you can do since there aren't any schematics available, would be to measure the 1 half and write down the resistance and do the same with the other half and add them together. You should go up a little also, say if you are reading 1 k ohm, use a 1.2k ohm in it's place. The other way is to follow it upstream to see what the resistor is supporting. If it's an I.C. you could look up the I.C. number and go to website to see what resistor is required to support that I.C.
SOURCE: Maytag Neptune m/n MAH3000AWW burnt R11 resistor
STOP
There is a short in the door lock (very, very common problem )
Go to ebay and search neptune washers and im sure youll find a site i was selling a kit to repair this. If you cant find it let me know ill look .
SOURCE: need resistor value for RK62 on DP2X board for 57SWX20B
RK62 is a 2.2ohm 1 watt metal oxide resistor hitachi part number 0700054M any 2.2ohm 1 watt resistor will work although it does have to be metal oxide(flame resistant) for safety purposes.
SOURCE: I need the value of resistor R1 on my model
Hi. I have access to the Service Manual for this model, the only technical information it provides is this:
- Voltage : 100-240 V AC 50-60 Hz
- Power consumption : Motor depending
- Motor Voltage : 1,2 V
- Power system : Rechargeable
If you have no luck, Part No 4222 036 09060 is for the PCB.
A copy of the Service manual was found also at http://www.shop-stecken.de/ecarusShop/v30/pdf/HQ6613.pdf
SOURCE: videocon crt tv poewr supply failure burn the
videocon crt tv vdf vc 232 is dead and fuse burns when swicth on
SOURCE: part list - resistor value of Gaggenau hood
http://www.gaggenau-eshop.com/eshop(bD1lbiZjPTAwOQ==)/gaggenau/gb/prodlg.htm?Maktx=ah900161&eshoptype=S
Hope this helps, you will need the full Enr to ensure you are checking the correct list.
Hope this helps.
if it is not showing whole vertically means your problem is in vertical output section.
please check
