Question about Golf
SOURCE: trickle charger for storing electric cushman golf cart
contact manufacturer, and seek there advice
Posted on Nov 27, 2008
SOURCE: I have a yamaha electric golf cart. The lights
I bet that it is an simple as a fuse that blown out. Try replacing the corresponding fuses.
Posted on Nov 07, 2009
SOURCE: Electric Golf cart only shutters and inches forward
so many possibilities...
does it roll fairly freely? (checking to see if the brakes or rearend seized up)
Are there any "bad" sounds like things grinding? (Connection between Motor and rearend, axle splines...)
If all that is solid, it is likely in the controller.... (it takes a solid charge right... No bad batteries in there or loose connection? might want to check all the battery connections to make sure none are burnt...)
1997.. does it have the electonic speed control by that year? the other possibilty is that the accelerator is not working corectly. they used a resistor system on old ones that has contactors that would get worn out.... Newer ones control a potentiometer(sp) that controlled the speed.
Only a few real components to check, but if you are not mechanically and electically inclined, could be tough to isolate.
peace,
Posted on Mar 07, 2010
SOURCE: 2004 Club Car DS Electric
One of the solenoids are bad and is be skipped over or the speed control box is malfuctioning.
Posted on Aug 26, 2010
Aug 17, 2018 | Golf
Jun 10, 2018 | Golf
Nov 05, 2017 | Golf
Mar 22, 2017 | Golf
Jan 24, 2016 | Golf
Aug 21, 2015 | Cars & Trucks
Aug 25, 2014 | Peg Perego John Deere Gator HPX Ride on...
Aug 04, 2014 | Yamaha G1 G-1 2-cycle Gas Golf Cart Tune...
Nov 07, 2009 | Electronics - Others
Jan 19, 2020 | Golf
Oct 16, 2019 | Golf
1,203 people viewed this question
