Question about Goldstar Dehumidifiers
Goldstar dh404e coils not cold throw out or reasonable fix
Goes on not dehumidifing
Posted by Frank Dougherty on
Marvin
    Top Expert:
  • Goldstar Master
  • 85,239 Answers
I would just replace it.
Posted on Oct 05, 2018
2 Related Answers
22yooper
James Helmer
  • 828 Answers
SOURCE: goldstar dehumifier #DH404E/GD40E --cannot turn the unit off. power button not working.
Yes is the answer to your question.
Posted on Nov 17, 2008
laura Newman
  • 415 Answers
SOURCE: fan and compressor run but coils not cold and no
If your compressor is running but the coils are not getting cold, then you have a problem in your refrigerant circuit.....Most likely a restriction or a leak with a leak being the more likely of the two.
Posted on Apr 30, 2010
Goldstar dehumidifer model GDH 30 wont turn on
first check outlet, some have a killer switch at base of unit, and if not setting level will not turn on.
Sep 30, 2011 | LG DH30 GoldStar Dehumidifier
I have a Goldstar Dehumidifier DH504ELY7 that doesn't pull moisture out of the room. the fan runs and I think I hear the compressor come on but the air coming out the back is cold and the bucket doesn't...
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 11, 2010 | Goldstar DH504EL Dehumidifier
The dehumidifer doesn't
sounds like your evaporator coil is dirty its the coil where the air goes in
Apr 08, 2010 | Whirlpool AD50USL Dehumidifier
Golstar dehumidifer
Either you are under sized. or it is over heating. 50 pint should be used in 1000sqft area. it maybe over heating or the vents maybe plugged one of these is your problem.
Jan 07, 2010 | Goldstar DH504EL Dehumidifier
I have a Goldstar GHD30 dehumidifer that I bought used last week. It's pulling 20-30 pints of water each day out of my basement so it appears to be working. The compressor only runs for 1-2 minutes at a...
yes cycles should be longer either that or the unit is keeping close to desired humidity. Also the unit is under sized 30 pint is for 400sqft. or 20 by 20 room. humidity should be 30/50 percent check your level desired room temp is 70 degrees but its a basemnt 60 works.
Jul 28, 2009 | Goldstar DH504EL Dehumidifier
Dehumidifier throws off hot air making the room very warm. Is that normal?
Yes! A dehumidifier is an entire AC system in one box. First the air passes thru a very cold coil causing moisture in the air to condense and run away. Then the air is re-heated thru a hot coil (the other half of the AC) and blown back into the room. The net result MUST be a net increase in temperature because of the heat added by the mechanical process.
May 17, 2009 | Goldstar DH504EL Dehumidifier
LG LHD45EL
The temperature sensor on teh suction return line from the coil has drifted out of spec and needs to be replaced. This sensor is part of the sensor assembly which plugs into the control board. I purchased the part from Appliance Factory Parts on line, cost about $30, an hour or 2 to change depending on your mechanical level, it is easy to do. For Goldstar DH404E part # was 6877A30013M, they are same part for many models but if this is not the right # for your model just get the right "sensor assembly" for your model and change it out. It consists of Temp/humidy sensor in coil, temp sensor in suction return line, and plug harness that goes to float switch. My uni is running like new again.
Oct 08, 2008 | LG LHD45EL Dehumidifier
No water in tank
have you turned them off, waited a long time, and restarted? if yes, but still problem, both have developed freon leaks. the coils may have "frozen over", verified by looking at them-do they appear frosty? caused by humidistats that are not functioning properly (starting to corrode)...try turning down the stats to allow motors to rest (and frost to melt)
May 27, 2007 | LG DH404E Dehumidifier
Dehumidifiers Logo
293 people viewed this question
Top Goldstar Dehumidifiers Experts
Sheldon Dedek
Tim Venetis
Tom Chichester
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
