SOURCE: Alpine CDA-9855 won't recognize SIR-ALP1
I also had this problem. I had to go through the menu into the setup and then into tuner settings. There should be an option called tuner area. If you set it to area 1 it should start working. For some reason the sirius only works on area one. Hope that solces your problem
SOURCE: Sirius Tuner
Having the same problem with the vm9512. According to Sirius, the Universal SCC1 will work, however it requires an additional Jensen specific "translator" that I have yet to find on any site thus far. Also, I asked the folks at Jensen and they said the Sirius tuner is "supposed" to be available this summer. Hmmm, we'll see.
Ron
SOURCE: Need to disconnect XM Tuner
the xm receiver is in the left rear quarter of van looks like between wheel well and rear of vehicle this is drivers side
SOURCE: Acura TL XM conversion to Sirius
You can get a Windshield Mounting kit and Sirius Unit and use the FM Frequency Modualator that is Built in and just not use the XM.
SOURCE: 2006 vw jetta gli sat radio, sirius expired, now want xm
U can't change the provider, the radio's are built to recieve sirius or xm, u can't have both on the same radio.
