Question about IT Works Cameras
Our Uniden cordless phone has quit showing numbers calling us (caller I.D. isn't working - stopped all at once)? ?
We get sometimes a message that says the battery is low, but we just recharge it and it works fine. Could that be what is affecting the caller I.D. which worked great until a few days ago and just quit working altogether?
Posted by Alison Lehto on
Tony Parsons
  • IT Works Master
  • 6,275 Answers
Posting this under communications equipment, rather than Cameras, is more likely to get a response
Posted on Jul 30, 2017
5 Related Answers
Anonymous
SOURCE: Uniden CallerID not working..
sell it off
Posted on Jun 17, 2007
funkyjacob
Jacob McNamara
  • 76 Answers
SOURCE: No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Posted on Dec 02, 2008
Anonymous
  • 505 Answers
SOURCE: Static on the line, not heard by the caller
this is not in the phone its in the line you need to let your service provider know about this problem so they can fix it
Posted on Mar 09, 2009
Anonymous
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
Chuck Badeaux
  • 95 Answers
SOURCE: uniden cordless phone 900 MHz
A phone uses a voltage drop to determine when it is answered or hung up. What is happening in your case is the phone or base unit, or worse yet the house wiring has a short to ground somewhere. This also cause the static you hear. You can get a regular phone and plug it into the same cord and see if it works normal. If so it is not the house wiring but the phone or base unit. If so you can only hope to find the short yourself which is very time consuming and difficult on modern digital units. Sorry to say it's cheaper to get a new unit than pay for repair. The only other thing that cause those symptoms is the batteries are going dead. I assumed you checked this first. If not you can try changing the battery pack on the phone.
Posted on Mar 28, 2009
I have a Sanyo digital camera but the batteries only last about 15 photos and then I get the battery low message or it switches off. If I take the batteries out and insert them again and get another 4/5...
My best guess is that you need new batteries. Even rechargeable batteries need to be replaced sometimes. I am pretty sure if you purchase new batteries for this, you will be just fine!
Hope this helps!
Jul 26, 2011 | Sanyo S870 Digital Camera
I put in new batteries...the camera works fine for four or five pictures and then the battery message comes on that I need new batteries. Sometimes that message comes on before I even get to take a...
Same here, not the batteries
1.2v rechargeable Radioshack 1600mah & 1500mah did work though...
If you eventually get it to boot, go to menu and pick coolpix batteries.
Apr 07, 2011 | Nikon COOLPIX L20 Digital Camera
Nokia phone not recharging
Technically, It would be an old battery issue, or the charger itself, try using another charger, if the problem still occurs, maybe it's the battery or your's phone's charger jack had a hardware issue.
Feb 10, 2010 | Nokia Lands Phones
Battery Low Message - Won't recharge
did u try connecting it to your computer like i do mine
Jan 24, 2009 | SanDisk Sansa e250 MP3 Player
Samsung S630 camera says "low battery" then shuts off
This camera needs rechargeable batteries usually lasts about a week with much use. I thought what a waste of batteries then tried these rechargable and the situation hasn't occured . it is probably because it is small digtal camera which uses alot of power.
Dec 31, 2008 | Samsung Digimax S630 Digital Camera
Blurry LCD monitor in Canon PowerShot A85
Sometimes humidity is the problem . Please keep the camera under room temprature and on position for maximum time . For the Battery low problem first try using alkaline or lithium ion batteries and see if they work fine...
Oct 12, 2008 | Canon PowerShot A85 Digital Camera
Short battery life?
I had a smiler problem with Alkali batteries. Thereafter I started using rechargeable batteries and also changed the setting to Ni-MH. Its working fine now.
Feb 26, 2008 | Nikon COOLPIX L10 Digital Camera
Caller ID is not working in India.
For people who have purchased cordless phone in usa and caller id is not working they should purchase fsk to dtmf converter at any local phone shop and caller id will start working.
Here is the article on various frequency used by various countries for caller id.
Hope this will help you out.
Detailed Product Description
There are 3 major caller ID specifications in the world: DTMF, ETSI FSK and Bellcore FSK. When users buy a foreign telephone devices(such as cordless phone, fax machine or computer telephony interface), may encounter the problems of non-match for caller ID standard. This will cause the device unable to display the caller ID. EX220 can solve this problem easily. This product can receive all 3 kinds of caller ID format, and convert to FSK(Bellcore or ETSI selectable) to match foreign telephone's standard.
EX220 has a rechargeable battery inside the device, during idle status, it gets power from the telephone line and recharge the battery, so no need to use or replace battery. Just plug one end to telephone line, and the other to the telephone device.
For example, if you live in Netherlands, Saudi or India, the caller ID standard is DTMF. You purchased a cordless caller ID phone from US(which uses Bellcore FSK standard), or from Germany(which uses ETSI FSK standard). You won't be able to use the caller ID feature. In this case, just get one EX220 and connect it between the telephone line and the cordless phone, your cordless caller ID phone will display the caller's number immediately.
Remark:
1. Telephone sets for UK and Japan standard are not applicable.
2. In some countries, users must subscribe to Telecom for caller ID service
Feature List
Caller ID Format Conversion --- Convert 3 kinds of caller ID(DTMF, Bellcore FSK or ETSI FSK) to ETSI FSK or Bellcore FSK(selectable)
Date/Time Stamp --- The DTMF caller ID doesn't content date/time stamp. User can set up clock of EX201, so each call will be sent with actual date and time stamp
Area Code Setting --- User can set up the area code, so the dial back feature can easily applied
Rechargeable battery powered by line --- Just connect to the telephone line, the built-in rechargeable battery can get power from the telephone line, no need any external battery nor power supply
News
Now, Multi-Line caller ID converter is available.
Dec 09, 2007 | Motorola Mobility 5.8 GHz Digital Cordless...
Line error on caller id
there are a very small capacitor in the board that produce low battery mesege when it get damage, but you gona need a tech to repair your phone there are another problem in your phone its not a seting problem...good luck
Aug 05, 2006 | Emerson EM-CKT9087 Corded Phone
Battery Problem
I figured out the problem. My AA battery recharger was not making good contact, so although it said the batteries were recharged, this was not the case. After fixing this and getting full recharges, the problem went away.
Aug 31, 2005 | Canon PowerShot A70 Digital Camera
Cameras Logo
222 people viewed this question
Top IT Works Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Bill Boyd
Are you an IT Works Camera Expert? Answer questions, earn points and help others
