I have a composite RCA plug cord going from my TV to a receiver. The receiver was just playing the audio on the left side, but now the receiver goes into protect mode. The receiver works fine on just the radio.
SOURCE: Blink on Sharp Aquos LC-32D43U
If your using a HD converter box, there is usually a blink when switching from an HD channel to a non HD channel. It is just adjusting from different pictures modes such as changing from a 480i channel/show to a 1080i channel. If this is the case, its perfectly normal.
SOURCE: No sound unless VIDEO signal is plugged into receiver
Connect the DVD player audio with digital coax into the digital audio connection as you described and the DVD video directly to the TV. Now switch the input mode on the receiver to DVD. Then switch the video output mode on the TV to correspond to the input you plugged into. Any source in 5.1 dolby digital or dts should now work properly and have picture too.
SOURCE: No Digital Audio From Sharp LC-37D64U
Try changing the the Audio Setup in the Digital Setup Menu.
If you have your manual, go to pg 11 and pg 28 for Digital Audio Output. If you need a copy of your manual, here's the link.
http://www.sharpusa.com/products/TypeManuals/0,1083,127,00.html
Page 11 has info on the problem and page 28 to solve it.
If that doesn't work, I would try downloading the latest software to fix is problem. Page 28
http://www.sharpusa.com/products/support/options/1,2310,,00.html?model_num=LC-37D64U&s_func_disp_id=27&x=42&y=11
SOURCE: I have a Sharp LC-37SH20U flat screen TV. The
The main video backlight board is dead,must be replaced.
