Question about Nokia 7610
Restart my nokia 7610 keeps on restarting automatically
Posted by whelz on
Anonymous
  • 175 Answers
Try removing your memory card. if it still the same reset your phone.
code: *#7370# backup first.
Posted on Nov 22, 2007
Restore original phone setting ? phone will restart
You can do a Master Reset to your Nokia 7610. This could restore your phone with default factory settings. You can get the master reset code for a Nokia 7610 from www.wickedunlock.com/nokia-dct-master-code-service/rs11wp10/ at affordable cost by submitting your IMEI number. All the best mate.
Aug 06, 2012 | Nokia 7610
7610 i forgot my password
hi there is simple method if you forgot the password switch off your mobile phone and restart it again by continuosly press the key star button,callbutton and button 3 for 3 seconds then the phone will automatically unlock.
Aug 28, 2010 | Nokia 7610
Automatic shot down of unit but still LCD still working?
my phone will be automatically restarted. and on the mobile screen it has a some lines. how to replace my original settings of nokia 7610
Aug 05, 2009 | Nokia 7610
3110c
got this from the net, maybe it helps:
The Problem with Nokia 3110c – Switching off and automatically restartingThis is what happens. Nokia 3110 hangs, gets switched off andrestarts randomly. More often, it restarts around 3 times or so andthen gets switched off.
Possible Causes and SolutionsCause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500KB, so as to keep things running smoothly on your phone and preventNokia 3110c from restarting.
Cause 2 – Changing Themes – Some people havereported that the phone restarts automatically when they try changingdisplay themes on the phone.
Solution – Don’t get your phone loaded with toomany themes downloaded from the internet or atleast, don’t switchthemes frequently. These themes, mind you, also load up things intoyour already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB datacable (or) Updating Music Library – A few people have reported thattheir Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but considerconverting all your MP3 music files to WMA and then store them on thememory card. Some users suggested this.
Disclaimer – Follow the suggested solutions at your own risk. The author is not responsible for any damage caused to your phone.
UPDATE:IT LOOKS LIKE A FIRMWARE UPDATE COULD FIX SUCH NOKIA 3110CRESTARTING PROBLEMS – RESOLVE YOUR ISSUES RIGHT NOW BY UPDATING YOURNOKIA 3110C FIRMWARE – CLICK HERE TO KNOW HOW YOU CAN UPDATE YOUR NOKIA PHONE FIRMWARE
Jul 23, 2009 | Nokia 7610
My phone 7610 is not on & restart 3times & then off !
try *+3+green key+power together un-till formatting appear on the screen
May 06, 2009 | Nokia 7610
Activaion code
*#4720# - Half Rate Codec activation. It will automatically restart
*#3370# - Enhanced Full Rate Codec (EFR) activation. It will automatically restart.
try one of those code, it is an activation, just try in order to restart your phone
Regards JAN_yuanjia
Nov 21, 2008 | Nokia 7610
Nokia 7610 start up problem
flash d cell one time.but u ll loose all info .
May 09, 2008 | Nokia 7610
Nokia 7610 switches off automatically
nokia 7610,
can be rectified..but it will just cost u much for repairs..once u let that to be repaired,another problem will *** in..
u should look for a new one..
Apr 07, 2008 | Nokia 7610
Restarting nokia 7610
dear
you have to do the manual format.press *, 3,call button and now switch on the handset .keep pressing for few seconds upto the message comes "FORMATTING" then release the fingers .but you will loss the data.try this
Nov 23, 2007 | Nokia 7610
Automatic restart
pls.format or press # call 3 then switch on
Oct 30, 2007 | Nokia 7610
Nokia 7610 Logo
165 people viewed this question
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Zaid Anarwala
Zaid Anarwala
