Turning the dial doesn't always engage the grinder though. Sometimes it takes a combination of turning it on and off and turning the dial. I thought a bean was jammed...I took it all apart, it is still doing the same thing.
Okay, I'm NOT going to ask how you turn the burrs.
* The starter capacitor is bad or disconnected.
* you can download the Bunn manual which has the wiring diagram on the back pages. This should be a FREE download. AVOID using the word "manual" as it will re-direct you to scam sites that charge for free stuff.
* I know following the wires is a bit tricky.. Especially on the G9-2 with everything doubled. Take your time or seek help from a tech or your vendor.
* The capacitor is round and usually attached to the motor like a 'hump' on the side or near the top. If you didn't take it apart then one of the wires in the switching side may be miss wired or loose. Check both for loose and correct wired. Careful around the capacitor as it may still have a charge!
Aloha, ukeboy57
P.S. The capacitor is used to kick start the motor with it's heavy burr plates. Oh, and if your still having problems with low power. Check the motor for burnt smell as you may have overheated and fried the motor. They usually have thermal resets, but if you kept forcing the reset to keep grinding then the motor is defiantly burnt out.
