Question about Philips Vacuums
How to dismantle the button assembly of philips FC9160 vacuum cleaner
Posted by Amran Mokhtar on
2 Related Answers
devocap
Devocap
  • 201 Answers
SOURCE: dyson vacuum cleaner DC04
I would suggest you invert the vacuum and remove the plate covering the spinning brush assembly. You should check the belt located on one side of the spinner brush to see if it is worn or broken. Also remove anything wrapped around the brush that could be affecting it. Ensure the brush is free to rotate and seated correctly. If the belt is worn or broken, or the spinner brush is unable to spin, replacements are available from a licenced repair facility. I hope it helps! Good Luck!
Posted on Jan 29, 2008
Anonymous
  • 120 Answers
SOURCE: How do I dismantle an Electrolux Ambassador II?
you don't, as a repairman, even i have a hard time opening them, and then the hardest part is putting it back together.
Posted on Sep 14, 2009
How do i open/dismantle a hoover telios vacuum cleaner ?
Hi there! Disassembling the cleaner beyond detaching the nozzle, wand and hose is not recommended. If you need further assistance we recommend taking your cleaner in to a Hoover authorized service center for inspection. Follow the link to locate the nearest service center to you. Service Center Locator
Thanks!
Jun 22, 2014 | Hoover Vacuums
Can't disassemble the foot
We can't provide instructions on dismantling the cleaner head, and would advise against attempting to do so as this procedure should only be carried out by a Dyson engineer. Dismantling the cleaner head will also void your 5-year warranty.
If you feel the cleaner head is not working correctly or requires replacement, please get in touch with us directly so we can provide further assistance. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). If it's necessary to replace the cleaner head, this should be covered by our 5-year warranty, as long as the cleaner has been used in accordance with the terms and conditions listed in the user guide.
Kind regards,
Jack
Dyson Online Customer Support
Jul 18, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
I have a philips marathon fc 9202 vacuum cleaner. it has worked fine for a number of years but suddenly has no power. what can i check to diagnose the problem?
hi there my name is glen from dublin ireland....
i cant solve your problem but can explain what is happening...
i've had 3 phillips marathon vacuums over the last 5-6 years and are by far the best vacuum on the market..
but over time the constant pulling and re-coiling of the flex is loosening the wires from their connectors deep inside the unit ...
its the only explaination i can think of ,as i've changed the fuse , the plug and shortened the flex and re attached the plug but to no avail..hope this helps, just buy a new one they're brilliant
Oct 08, 2010 | Philips Vacuums
My son dropped the Hoover Floormate hard floor cleaner and a black piece with a spring came out. I dont know where it goes, and now the handle wont stay up.
From your description you have an issue with the pedal release in the base. this model is the original series, and I would not put too much money in the repair. not an easy cover to remove. check the base wheel assembly. the black pivot points break on these when dropped. If it is broke the part itself cost about $18. Cosider the overall performance and other repair items to determine worthwhile repair.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 03, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Sep 14, 2009 | Vacuums
Fitting a new electricity cord
remove the wheels then you can see the screws not easy to remove the wheels they just pull of
Jul 28, 2008 | Dyson DC05 Cylinder Bagless Canister...
Dyson vacuum cleaner DC04
Jan 29, 2008 | Vacuums
Vacuums Logo
Top Philips Vacuums Experts
Tim Venetis
JonSnell Electronic
JonSnell Electronic
Attique-ur-Rehman
Attique-ur-Rehman
Are you a Philips Vacuum Expert? Answer questions, earn points and help others
