Question about Cisco Computers & Internet
I need password for Cisco Router model E1000. User name is Cisco41070.
Posted by Jamie Evans on
theeggspert
    Habit-Forming:
    New Friend:
  • 15 Answers
This is not a default username for this router. you will need to reset the router to get back into it. There is a reset button to press to get it to its default configuration. Then the default username is blank and the password is admin.
Posted on Sep 05, 2017
5 Related Answers
Hollyecho
Hollyecho Montgomery
  • 318 Answers
SOURCE: forgot my user name and password
The default username for the router is admin all lower case. The default password, is blank.
Try this first - if that does not work, you will have to set the router back to factory defaults, then do any setups on it that you had before.
To perform a reset on the Actiontec - Press and hold the reset button on the back of the Gateway for 15 seconds. This will reset the unit back to its factory default settings.
Posted on Mar 29, 2008
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: I can't remember my user name and password to my router
You will need to reset the router. On the back of the router hold down the reset button for 30 seconds release the button and then wait for the power light to stop blinking. If it doesnt stop blinking within 1 minute unplug and wait 30 seconds plug back in and the router will be reset
Posted on Feb 15, 2009
kvgopi
Gopi Venkatesan
  • 74 Answers
SOURCE: user manual for cisco 1800
1800 series is a MSR (Multi Service Router) with that you can build a network with voice,data and enhanced security. In selected models Wireless is also available.
Check the manual in the following link
http://www.cisco.com/en/US/products/ps5853/index.html
Posted on Mar 17, 2009
Anonymous
  • 33 Answers
SOURCE: D Link DIR 635 - need to reset user name and password !
You can press the reset button on the DIR-635 which will reset the device back to it's factory defaults. Then connect using the factory default user id and password. (ID: Admin password is blank)
Anonymous
SOURCE: ip router and login name / password
yea but that backdoor got hack so wtf do i do when : user name root psw RM6008 dont working. ?
and wft a Backdoor on a router Who`s so stupid to make that
Posted on Jul 29, 2009
How do i access my port forwarding if my cisco router cant even log me in? are there preset defaults?
You can do a reset on your router. After the reset, the password goes back to the default, which is admin
Jul 22, 2013 | Cisco Linksys E1000 WirelessN Broadband...
Help!!!!!!!!!!!
Leave the user name blank and enter the password admin ( admin once only ).
Try this.
If that doesn't work then search for the Cisco connect software on your main computer. You might have installed the cisco connect software on your main computer while installing your router.
If it is windows computer then cisco connect software might be under All Programs.
If is a MAC computer then cisco connect might be under Applications.
Open cisco connect software.
Click on router settings. You will see the router name and password. If you click on Advanced settings, it will open the setup page.
If nothing is working then you will need to reset the router and reconfigure it.
Remember once you reset the router, you will need to reconfigure it from the scratch.
Click to see more information about cisco connect software
Apr 12, 2012 | Cisco Linksys E1000 WirelessN Broadband...
I secured my router network. I trying to get to set ups.... what user name and password I use? Admin for user name??
username: admin password: admin if that doesn't work, just reset it.
- reset instructions -
Push in the reset button on the back of the router, just to the left of the power port, for approximately 10-15 seconds, then wait 30 seconds, you will then be back at factory defaults. you then login to the router by typing http://192.168.0.1 into your browser, username: admin password: admin
Sep 20, 2011 | Cisco Linksys E1000 WirelessN Broadband...
-where can i find my cisco password? -what is my user name and password?
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Let me know if you need further assistance. Thanks for using FixYa.
Jul 02, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Need to find my wlan code Using Linksys cisco
Dear Friend!
Please write 192.168.0.10 in explorer and enter
User name and password : admin
Please vote after working.....
Best regards,
Pramod Bhikam Singh
Apr 22, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I have a Cisco E1000 N Router. Is it possible to have multiple SSIDs? for example, Can I have a network SSID for inside my home for multiple computers/printers and then another SSID for guests?
The SSID (Service set Identifier) is the NAME you give the wireless network (the Name of the router) and you can only have one.. BUT you can have a seperate password (key) for guests to access the router.
Feb 07, 2011 | Cisco Linksys E1000 WirelessN Broadband...
What do I do if I forgot my password?
Type 192.168.1.1 on the address bar of your web browser
Now you will be prompted for login details.
Enter login details of Wireless N Router
User Name: (it should be blank)
Password : admin
After entering the details click OK. Now you will be in on the web based setup page of Linksys E1000 Wireless N Router. Click on wireless tab on top as shown in the picture tgere you would see your password.
Hope this helps you.
Dec 26, 2010 | Cisco Linksys E1000 WirelessN Broadband...
Open Questions:
Computers & Internet Logo
47 people viewed this question
Top Cisco Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Jax Planet
Jax Planet
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
