Question about Frigidaire Ovens
SOURCE: F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Posted on Apr 02, 2009
SOURCE: Frigidaire double oven beeping and showing f8 code
Hello there
First i would unplug it for 1 hr to allow the oven internal reset to reset it'self than plug it back in and see what happens but if this doesent help than here is a listing of the code and what it means
F8
Lock motor relay watchdog is ative when it should be off
Microprocessor
checking the operation of the EDC lock relay after self
clean is selected, relay failed. Replace EDC.
Lock switches
Check or Replace
component
Posted on Dec 31, 2009
I appreciate your post, C Maury!
From my understanding your hit the clean button on your Frigidaire wall oven and now the door will not open. I would hold down the cancel button for at least ten seconds, this should unlock the door. If that does not help I would recommend disconnecting power from your wall oven by flipping the household circuit breaker for ten minutes. I hope this information was helpful to some degree. -Matt
Oven Control Beeps
and Displays an "F"
Error Code
Electronic control has detected a fault condition. Push CANCEL pad to clear the display
and stop the display from beeping. Reprogram the oven. If a fault reoccurs, record the fault
number, push the CANCEL pad and contact an authorized servicer.
