Question about Electrolux Washing Machines
SOURCE: electrolux ewf 1435 washing machine
i can not find e50 in any of my servive manuals, are you sure it is e50 ?
Posted on Feb 19, 2008
SOURCE: whats is the total weight of electrolux ewf 1495?
thas a question that the manufactuer should be able to answer for you, ifnot the dealer that your goingto purchase tehunit through should be able to get you those specs.
Posted on Mar 12, 2009
SOURCE: Broken front loader washing machine
take the back off and see if the belt has come off. is it draining water? if not make sure nothing is blocking drain pump
Posted on Apr 23, 2009
SOURCE: A washing machine Electrolux EWF 1025 does not start up.
E50 is displayed if the there is no drum rotation. drum jammed not allowing motor to turn/ no circuit through motor(poss worn out carbon brushes) less likeley but poss short on motor relay on electronic board.
Posted on Jul 24, 2010
Hello - Are you certain the error code is L60? This manufacturer does not have any (L) error codes for any washer or other units.
Hello - From what you have described it sounds like the washer could possibly have a communication problem with the control board not responding. Since you have already replaced the door lock, I would strongly suggest contacting a professional to accurately diagnose the unit.
