Question about Yamaha Audio Players & Recorders
My yamaha htr-5230 is not working and has a message on the screen "ex , decoder". any ideas on how to fix this? I powered off for more than 30 seconds and still have the same message.
Posted by Brad Plemons on
Travis Haynes
    Welcome Back:
    Visited the website for 2 consecutive days.
I got a Yamaha model number HTR 5230 Power on no sound
Posted on Aug 09, 2022
5 Related Answers
John Weinreich
  • 336 Answers
SOURCE: turns on then off.
It probably needs a set of output transistors, 2 pre-amp transistors and a 5.6v zener diode. Possibly a resistor or two. I've fixed many of these. Definitely a job for a pro.
John W
Posted on Jan 10, 2009
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: trying to program my Receiver, a Yamaha HTR 6130 to the AUX on my Comcast remote, but neither of the codes they gave me seem to be working.
Do a code search from comcast. If you have the Comcast manual it shows you how to search for codes manually, it can take 15 to 20 minutes for you to do it, however, it should fid your code. The only drawback is that you can only control the volume and power, you won't have input or soundfield control. Hope this helps
Posted on May 24, 2009
heavyice
Fardin Ahmed
  • 374 Answers
SOURCE: Microphone for my YAMAHA HTR-5440
Let me make this clear to you that your Yamaha does not support Microphone but the trick is you can still do it. All you need is a stereo jack to a RCA connector cable.Check this out http://www.mediacollege.com/audio/connection/jack-stereo-rca-2.html It is easily available in the market. The stereo jack will fit into your microphone and the RCA to your Amplifier/Reciever. Plug the RCA into CD/Tape input but not in the Phono n do your thing. Let me know if this works,coz I'm really curious.
Posted on Jun 02, 2009
Anonymous
  • 4234 Answers
SOURCE: no sound from htr-5840 when switched on. I hear
These units have protection circuits that will prevent the speaker relay from engaging if there is a problem detected. There is also a circuit that causes a delay in the engaging of the relay to allow the amp to "settle in". This prevents the old "thump" that was common in older models when the set was first turned on. In your case, either the RC circuit is faulty causing excessive time to pass before turning on the relay, or there is excessive voltage floating around that the protection circuits are detecting and thus preventing the relay from turning on.
In any case, this will require additional diagnosis using some test equipment. This is not a problem that will be easily resolved remotely. Please bring this unit to a repair shop for an estimate. Once you have that info, we can assist with the actual repair.
Dan
Posted on Aug 25, 2009
Anonymous
  • 3489 Answers
SOURCE: Yamaha HTR-5660 Power Problems
i talked to my father in law who knows quite a bit about these. your only option is replacement. i wish i had better news. i know what they cost and i have one as well.
Posted on Jan 19, 2010
Yamaha HTR-5230 - A/V receiver with Dolby Digital
Check the connections at the back, and if they are okay, take it to Yamaha service unless you are an audio engineer. If you are, here is the Service Manual.
Yamaha HTR-5230RDS Service manual ' Manualzz
https://manualzz.com > ... > DVD players
View online (76 pages) or download PDF (10 MB) Yamaha HTR-5230RDS Service manual • HTR-5230RDS DVD players PDF manual download and more Yamaha online ...
Yamaha HTR-5230 Manuals - ManualsLib
https://www.manualslib.com > ... > Receiver
Manuals and User Guides for Yamaha HTR-5230. We have 4 Yamaha HTR-5230 manuals available for free PDF download: Service Manual, Owner's Manual ...
On Yamaha HTR-6295, optical input, I get no sound and a message "Decoder Off". Book says to switch the decoder to "auto', did that. Tried a different bluray player and a different optical cable.
Hello Garry, ask, have you tried on both AV1 and AV3 fiber optic inputs on your Yamaha?
Because apart from these two inputs of Fiber Optics, the Yamaha, has an Optical Fiber Output, which could lead to a connection error
I sent you the link of the User's Manual so you can download it, on page 5, it shows the back panel of the HTR-6295
I hope my comment has served you
Greetings Franco Dosil
Hola Garry, pregunta, has probado en las dos entradas de fibra optica AV1 y AV3 de tu Yamaha?
Porque aparte de estas dos entradas de Fibra Optica, el Yamaha, cuenta con una Salida de Fibra Optica, la cual podria llevarte a un error de conexion
Te envio el link del Manual de usuario para que lo descargues, en la pagina 5, muestra el panel trasero del HTR-6295
Espero te haya servido mi comentario
Saludos Franco Dosil
https://ca.yamaha.com/files/download/other_assets/2/324702/HTR-6295_C.pdf
My yamaha amp is now showing decoder off & it doesn't recognize my speakers as it's surround sound with 4 speakers
go to this website to see what happens to your amp.
http://faq.yamaha.com/us/en/article/audio-visual/av-receivers-amps/htr/htr-3063_black__u/4875/4196/
Yamaha HTR-5230 5.1 Channels Receiver turns off as soon as you turn it on, it does this with or without anything connected to it
To be able to isolate the problem, you gonna need to disconnect the power amp output transistor(pair) one at a time. :)
1helpful
My yamaha htr 5230 shuts off everytime i turn the volume up at all
Check the speker wires could be shorting out to the cabinet. If you still have the problem remove one speaker at a time.
Probably a bad speaker or wires.
Yamaha htr 5240 receiver, need fm antenna adapter
this is your manual http://www2.yamaha.co.jp/manual/pdf/av/english/re/HTR-5230.pdf
this is the 300 ohm adapter you need from radio shack and just install some small gauge speaker wire to it. or just splice the one that came with your receiver.
http://www.radioshack.com/product/index.jsp?productId=2062054
3answers
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
2answers
Subwoofer
i have the same tuner.on the back you will see all connectors bottom row of rca jacks you will see subwoffer if your sub has to rca. red/white use a splitter monstor cable gold ..works best. i use Home Theater Reserch speakers... you can also plug your subs power plug into the tuner snd you never have to power it on seprate .........
Top Yamaha Audio Players & Recorders Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
