SOURCE: choke on a suzuki gs1100 gk /mikuni 34mm carbs
cables too tight , poor lubrication of choke and or throttle cable
SOURCE: bike wont run when choke is at half way setting
Sounds a lot like fouled fuel jets in your carb; you may have a little work to do.
If the jets do not allow sufficient fuel to pass, using the choke can 'cheat' the carburetor by restricting the flow of air and restoring the fuel-air ratio.
You can't ignore this problem since the 'cheated' condition does not let the engine develop the power for which it was designed.
SOURCE: 1987 rm 125 starts and idols fine, bogs out on take off!!!!
Pull the slide out of the throat of the carb then move the clip at the top of the needle down one notch, two if needed. This will richen the low end fuel mix.
Need a "very helpful" rating asap. Thanks!
SOURCE: 400 Eiger ATV, starts and runs fine, stalls the
If 2 stroke check crank seals, check plug cap for proper resistance,check for good fuel flow to carb.Spark should jump at least a 1/4" gap,NOT JUST the .030 or plug gap.
SOURCE: 196 cc baja mini bike dies if I try and give throttle
I have a 196cc baja, it has no power going up hills
