Question about Seiko Audio Players & Recorders
How do i set time on Seiko radio wave control wall clock AM 220 B .
Posted by Carmen Tartaglia on
cwradio73
  • 1,162 Answers
5 Related Answers
Anonymous
  • 56 Answers
SOURCE: How to set clock....
http://www.bose.com/pdf/customer_service/owners/og_wrcd.pdf Hold down either Time < or Time > or press either button twice in a row... clock should start flashing
Posted on Aug 15, 2007
Richie_asg1
Richard Perkins
  • 1036 Answers
SOURCE: setup a clock on the wave radio
There should be two buttons on the top of the main unit- right towards the back saying "Time" with a left and right arrow.
Press individually to advance single digits, press and hold to skip faster.
Hope this helps.
Posted on Jun 13, 2008
m22loud
  • 136 Answers
SOURCE: setting clock on pioneer radio
you will need to turn unit off then press function button for a few seconds this will take you to the clock function.
Posted on Sep 05, 2009
Anonymous
SOURCE: Radio controlled clock model 6302000 - cannot
I have the same clock and had the same problem. My clock was a demo and had no instructions with it. Here is the solution:
1. Pull out the battery and wait 10 seconds then replace the battery. The satellite symbol should start flashing after a few seconds.
2. Put the clock outside or in a window sill till it updates. This could take a couple of minutes.
3. Press the Mode button once to enter programming mode.
4. Press the Adjust button as many times as needed to toggle through the time zones.
5. Press the Mode button once to exit programming mode.
Posted on Oct 08, 2010
Anonymous
SOURCE: I can't change the time of the clock on the Hyundai 50645P CD player/AM FM clock. There is no information in the Sante Fe manual. Any advice?
Try this, put the key in the ignition and let it be on the first turn right marked "ACC" or you can turn off the stereo and you will notice that only the Digital Clock screen will show. Turn the Volume/Audio/Sel knob and press on the "DISP" button simultaneously for about 4 seconds then release the "DISP" button. The digital clock will start blinking, and then use the Tune/Seek arrows pointing up and down to change the time. If the hour digit is blinking change the hour and after you have changed it press "DISP" then the minute digit will start to blink change it using the arrows, when you are done press "DISP" again or leave the clock for between 4 to 8 seconds the clock will start working normally.
I hope this works for you.
Aquinas
Posted on Oct 11, 2010
How can I get the correct day of the week? I can get the date-month & day, but not the correct day such as Sat when the clock says Monday.
check you have set to the correct year, and remember a leap year has one day more... note date,month stays the same but the day changes from year to year.. hope your clock has a year function?
May 12, 2016 | Seiko Global R-Wave Radio Controlled...
How do I change the time zone?
You may have to do a time set for the particular time zone you wish.
Mar 13, 2015 | Seiko QHR015SLH R Wave Get Up and Glow...
QHR021S
To reset the time on the Seiko QHR021S proceed as follows:
Press and hold the "Reset" button on the back of the Seiko QHR021S with the tip of a pen until the "Seconds" hand starts to move rapidly.
The "Seconds" hand should stop at "12". Then the "Minutes" & "Hours" should also work their way round to "12".
Give it a few minutes until it picks up and synchronises with the radio time signal and the clock should then adjust itself to the correct time.
Apr 30, 2013 | Audio Players & Recorders
SEIKO CLOCK MODEL QHR016 HOW DO YOU SET UP TIME, DATE AND ALARM ?
Once the 'SET' button is pushed & held, & the numbers are flashing, turn it around to the face & use the ALM/TIME set buttons to adjust the numbers correctly. Then, continue on pushing the 'SET' button to cycle through the number positions & adjust everything else in the same way. Then, for language & temperature readout choices, push the 'OPTIONS' button & use the same ALM/TIME set buttons to cycle through the options, making your preferred choice. Be sure to push the 'WAVE' button to choose your proper region so it can receive the time signal. Worked for me. I use lithium primary AAA cells for the longest life.
May 20, 2011 | Seiko QHR016SLH Clock Radio
I HAVE A SEIKO GLOBAL RADIO WAVE CONTROL MODEL QHR019SLH AND NO MANUAL HOW DO ISET THE TIME
Remove the battery cover, press and hold set until it beeps. Use the up down keys on the front and you cycle through year, month/day, then time, then 12/24 hour mode. You advance to each function using the set key. Once through the cycle, the time will stop flashing and the clock will function normally.
Nov 09, 2010 | Seiko QHR016SLH Clock Radio
Need users operating manual for seiko qhr016 travel atomic clock
The time should be done on automatic by pressing WAVE.
To set manually:
Press the [SET] Button for more than 2 sec. The Year will pop up set to correct year then press SET again to set date/mth, keep holding till it get to right month n date (the month and date does not set separately). Press SET again and set TIME then press SET again for your choice of 12hr or 24hr.
Apr 26, 2009 | Seiko QHR016SLH Clock Radio
1,480 people viewed this question
Top Seiko Audio Players & Recorders Experts
NOEL
NOEL
Andrew Taylor
Andrew Taylor
barn2897
Are you a Seiko Audio Player and Recorder Expert? Answer questions, earn points and help others
