Question about In Office Equipment & Supplies
150 Ml in grams
Shaving cream on a tube 150 ml how many grams?
Posted by maria garreffa on
John Porter
    Scholar:
  • 96 Answers
Hi...150 ml equates to 150 grams, thanks,
Posted on Jul 26, 2017
5 Related Answers
paultech8226
  • 109 Answers
SOURCE: Hobart 24 in. LXIC fails sanitizer tests.
I thought it was designed for domestic bleach at 5.25%, and looking for a solution of 50 ppm of sanitizer and rinse water. Either the elbow is blocked, or the silicone tube in the pump has collapsed. Use rubber gloves and face protection when working on chemical tubing.
Posted on Aug 13, 2009
Testimonial: "It was a collapsed tube. Thank you for your helpful insight. If you read all my comments added on July 11 you will see your answer verified."
Anonymous
  • 17 Answers
SOURCE: configure & install two scsi disks scsi disks in ML 150 G2
The SCSI driver is required to installed during the initial boot up for installation when additional drivers are asked .the new models dont come with a Floppy drive so an external floppy drive can be used .The detection of HDD s must be at the startup by the Bios os SCSI card.
Posted on Mar 12, 2010
louislevel_2
Louis Magpantay
  • 374 Answers
SOURCE: capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
Posted on May 08, 2010
info2u
Nouveau IT, LLC
  • 596 Answers
SOURCE: how can install windows xp in proliant ml 150
As long as the server meets the XP minimum spec, you can insert the XP boot disc and reboot your server. As long as the CD/DVD is bootable, you should be ableto install XP without incident.
Good Luck,
C2Solutions
Posted on Nov 25, 2011
goravsharma
SOURCE: firmware of ml 1666
need for samsung ml 1666 chipre set software
Posted on Aug 23, 2012
How many ml is equal to 18mg
Depends what you are measuring. You need to repost with the material that you are measuring.
For example, 1 litre of water weighs 1 kilogram.
So, 1 litre of water weighs 1,000 grams.
Thus, 1,000 millilitres weighs 1,000 grams
So, 1 millilitre weighs 1 gram.
Thus, 18/1000 millilitres weighs 18/1000 grams.
I get 0.018 ml = 18 mg.
Good luck,
Paul
Feb 07, 2017 | Office Equipment & Supplies
If I have 300 grams of milk how do you convert that into oz's
The metric system is easy in one aspect. 1 ml = 1 gram. If you are looking for liquid conversion you have 300 ml of liquid. 100 ml is 3.4 oz so you have about 10 oz of milk.
Oct 10, 2014 | Coffee Makers & Espresso Machines
How to convert 80 ml to 80 mg
Hmm injection eh?
Well, 80 mg is not 80 ml, nowhere near.
For pure water 1 ml is 1 gram. So 80 ml is going to be 80 g which is 80 000 mg. This all comes form the base relation 1 litre (1000 ml) is 1 kg (1000 g).
For other substances, it will be a bit more or less than 1 gram in a ml, but not much.
It would help us both to know what is the injection, we are not the police.
Aug 17, 2014 | Cars & Trucks
WHAT IS THE DIFFERENCE BETWEEN MG AND ML
A Milligram is MG and a Milliliter is a ML. (MG) is used in dry measure and (ML) is used in liquid measure
1000 micrograms (mcg) EQUALS 1 milligram (mg)
1000 milligrams (mg) EQUALS 1 gram (g)
1000 grams (g) EQUALS 1 kilogram (kg)
1 kilogram (kg) EQUALS 2.2046 pounds
1 ounce EQUALS 28.35 grams
1 pound EQUALS 0.4536 kilograms
1 pound EQUALS 16 ounces
16 ounces EQUALS 453.6 grams
1000 milliliters (mL) EQUALS 1 liter (L)
1 liter (L) EQUALS 1.0567 quarts liquid
1 quart liquid EQUALS 0.9463 liter
4 quarts EQUALS 1 gallon
Jun 28, 2014 | Health & Beauty
How many mg in 12 ml?
Milligram is a unit of mass (or weight). Milliliter is a unit of volume. The conversion depends on the density of the substance.
12 ml of water weighs 12 grams or 12,000 mg. 12 ml of gold weighs about 235 grams or 235,000 mg.
Jun 26, 2014 | Casio FX-115ES Scientific Calculator
Convert one mg to ml
mg is a measure of mass, ml is a measure of volume. There is no direct conversion between the two. A ml of water masses one gram, while a ml of gold masses over 13 grams.
Dec 09, 2013 | Office Equipment & Supplies
How many grams is equal to 50 mls
Gram is a measure of mass or weight, milliliter is a measure of volume. 50 ml of water will weigh about 50 g while 50 ml of mercury will weigh quite a bit more.
Jun 24, 2011 | Office Equipment & Supplies
What is the difference between ml and grams. My
one is for measuring liquids (ml) and one is for measuring solids or dry materials (gms). A reference 237 ml is equal to 1 cup which should work for cottage cheese.
Mar 26, 2010 | Grilling
In a 1.5% lidocaine solution, how many grams of lidocaine would be present in 10ml?
Hello, I can help you if you include more data in your question.
As an organic compound, lidocaine is insoluble in water, so I am assuming that either some combination of water and alcohol (ethanol), or a pure organic solvent like ethanol or diethyl ether is being used.
If lidocaine were soluble in water (which it's not), you would have been able to solve your problem as indicated below. Maybe you would be able to modify the indicated solution by taking into consideration the density of the organic solvent.
Percentage (%) by mass is one of the common ways to express the concentrations of solutions.
Since % means the number of grams of solute in 100 grams of solution (solute + solvent), a 1.5% solution of any solute refers to 1.5 grams of it in 100 grams of solution.
Assuming we are referring to an aqueous solution (that is, where water is the solvent), this reasonably approximates to 1.5 grams of lidocaine per 100 mL solution. We can assume this result, because we have a dilute watery solution, which probably has the density close to the density of pure water, which is 1.0 gram per 1.0 mL at commonly used temperatures, such as average room temperature.
So, 1.5 g lidocaine per 100 mL solution can easily be scaled down by one-tenth to give:
0.15 g lidocaine per 10 mL solution.
Sep 23, 2009 | MPS Multimedia QuickStudy Chemistry for PC
35 people viewed this question
Top In Office Equipment & Supplies Experts
Marvin
Marvin
Paul Carew
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
