Odometer
The odometer is an electronic digital display. Digits displayed are illuminated by the odometer backlight bulb. The odometer backlight bulb brightness is controlled by class 2 messages from the BCM to adjust the display for daylight and instrument panel dimming operation. The trip odometer and total odometer will show in this display area. The push button in the lower right side of the speedometer is used to toggle between the trip and total odometer readings. To reset the trip odometer, push and hold the button down for at least two seconds. The total odometer display has six digits with no decimal display. The trip odometer has four digits including a decimal point and indicates tenths of a mile or kilometer.
The body control module (BCM) stores the vehicle mileage. If the BCM fails, the cluster will display the last valid mileage that was sent before the BCM failed. For replacement of the BCM refer to the BCM section of this service manual. Replacement instrument clusters do not require odometer pre-setting before installation. If the instrument cluster is replaced, the mileage stored in the BCM will be sent to the new cluster via serial data, and shown in the odometer display.
Your best bet , take it to a qualified repair shop.
SOURCE: odometer not working
I had the same problem with my '94 Sl2. You have to take out your gages and send them in to get repaired. It is a little wheel where the odometer is that isn't working. The odometer is a speed rated so it is only activated by your car computer.
SOURCE: 2002 SATURN L200 - CANNOT READ ODOMETER IN THE DARK
needs a backlight bulb this can be easily replaced by removing the cluster.
SOURCE: 2002 Buick Rendezous odometer reads "error"
sound like odometer worn out or wiring problems.
SOURCE: 2003 Saturn L300 odometer reads 694,278 miles and
change the whole instrument cluster with one from a wreck.
SOURCE: Odometer stopped working
A replacement gear is available online for $25. I beleiev the site had spedometer in its name. Site has very good instructions. I've done two now and ready to do a third. OEM gear junk made of Polyurathane.
