Question about Lanier Office Equipment & Supplies
Lanier LD035: Smug on drum.I took drum unit out cleaned drum . Put it back in got error code 819 6261 0x64206469.
Lanier LD035: Copies were displaying a lot of dust. I replaced toner, drum , and developer. Hit copy sample. It work fine except smug on drum. I took drum unit out cleaned drum . Put it back in got error code 819 6261 0x64206469. Will I need to replace hard drive or simply replace drum to clear error? No technician available for my area.
Posted by Bre Rive on
5 Related Answers
Soulvisitor
Soulvisitor
  • 1113 Answers
SOURCE: Dust on Drum message after installinng new Drum
Dust on drum refers to as you correctly stated the wire, it carries a electric charge that transfers the image. If the wire gets contaminated the electricity dont flow right so dust on drum is desplayed, you drum cart is faulty, they are not repairable items, go buy another then claim new/old one as faulty from them. Um aH.
Posted on Dec 19, 2007
Anonymous
  • 53 Answers
SOURCE: xerox 5305 copier excess toner
sounds like faulty drum cleaning blade,which is usually contained in the replacement drum module.I would be inclined to take the drum unit back where you got it (unless you replaced it with a second-hand one) 99% certain the problem is contained in that module
Posted on Feb 27, 2008
Anonymous
SOURCE: Aculaser C2600 "clean sensor" message
This is a common characteristic which arises from using improperly remanufactured toner cartridges.
Otherwise it is a bad Epson original one - which is highly unusual!
When the C2600 runs through its calibration it prints strips of each colour on the transfer belt which are sensed for density. You will get a "clean sensor message" if the reading for any of the strips drops below a certain value.
The first thing to do is to depress the clean sensor lever behind the front cover several times . If that doesn't fix it I would advise you to remove each cartridge in turn (go to reset menu and scroll down to change toner) and inspect the toner on the surface of the roller. If there is any form of "sheen" then you'll need to replace the cartridge.
It is possible to adjust the doctor blade if you know what you're doing but be careful as there are shims on each side. Loosening and moving the blade bar towards the roller slightly, refixing and then turning the side cog to rotate the roller can sometimes resolve problem. Not a good idea really unless you're in an emergency.
There are some good remanufactured cartridges and bad ones. If you want to avoid this buy genuine Epson cartridges - I know they're expensive but what does the down time cost!
Posted on Jun 19, 2009
Anonymous
SOURCE: Dust on Drum...
I had this problem too. I took out the drum and vacuum the drum with a vacuum cleaner ( no brush ) while at the same time manually rotate the drum cyclinder. It worked. After a month or two, you might have to do it again. But everytime, it solved the dust problem.
Posted on Nov 28, 2009
mike roark
  • 158 Answers
SOURCE: Konica/Minolta biz 350 C2557 after replacing DV unit and drum F8
tha minolta di3510 developer unit looks the same as the unit for the konica minolta bizhub 350 but the toner sensor in the minolta unit uses a different voltage range for the toner sensor and it will throw this code make sure you have the correct unit for this machine also you can try this
go back into tech rep mode and change these settings:
select tech rep choice mode
select printer tab
select atdc sensor gain
set the value to about 165
then back all the way out to the ready screen and power the machine off then back on and replenish toner in the user management screen.
Posted on Nov 05, 2011
Copy quality
run the CLEAN mode.
or
Remove the toner cartidge and clean the rollers.This happens when you use cheap paper. The dust gets on the roller drum and grays or streeks the copies
Apr 04, 2013 | Lanier Office Equipment & Supplies
Problem with Konica 7145.. When i make copies it duplicates some lines and reprints them lower on page (more faded) and also the first lines of the copy are blured in a point that they are not readabl
Manousos Xatzidakis:
I would take another look at the drum cleaning blade as well as the CEL and PTL. Any time I've had problems with double images, the drum carriage and parts associated to it have been the problem. I remember one notable case where I removed and shrouded the drum to protect it from light, cleaned both the charge corona and the discharge corona, cleaned the PCL and the PTL of toner dust, vacuumed the drum carriage of toner dust, cleaned the developer unit and replaced the developer. I finally got clear copies and the customer was satisfied.
Sep 22, 2012 | Konica Minolta Office Equipment & Supplies
Ir 6570 copy light
When you were replacing the drum did you tuch the drum surface?Best would be that you take some toner on piece of cloth, and polish the drum, while turning it in good direction, that the cleaning blade can clean it.After you must let it copy about 50 copies.
You can try to replace the whole drum unit cexv14, or clean the laser unit.
Also could it be that the toner unit, or toner cleaning blade are not properly distibutes the toner accross the developing/toner cylinder
May 07, 2012 | Canon Office Equipment & Supplies
When I make copies from my kyocera cs 4035 the copies are very light or transparent could this be the drum?
It could be developer and it could be toner, first try to shaking the toner or put new toner, if it does not help, try refresh the developer. if you increase the density and it comes ok! this means is not the drum unit.
How to refresh the developer:on the panel: hit 1087 1087, this will take you to the service mode.press on the panel 130 and press the Start Button.select dv refresh from the screen,then hit Start again, the screen numbers start change, it will take about 5 minute or more until it finish.
To exit the service mode, hit reset two times,until you see the screen has zero numbers, and then hit one then start button.
This should takecare of your problem,
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Dec 30, 2011 | Kyocera CS-4035 Copier
The developer box does'nt keeps toner in it, is it probably because of already 'old developer' or do i need to add some developer...how much is developer? Mine is toshiba e45. Thanks a lot.
Hi
The developer life span is about 150.000 copies, then it should be replaced.
If the developer has not done 150.000 copies then there could be another problem.
The cost of the developer is about R1000.00. {in South Africa}
Please remember that the life span of the drum and drum cleaning blade is also 150.00 copies, so the developer, drum and cleaning blade should be replaced at the same time.
Regards
Apr 12, 2011 | Toshiba e-Studio 45 Black and White Copier
My lanier is making dark copies
One of the most common reasons for a Lanier 5222 or 5227 to make dark copies is a problem with the drum unit or developer. Fortunately on those machines, the drum unit and developer are all self-contained in one easily-replacable unit, called the PCU (photoconductor).
If you don't have a new PCU handy, you can order one from the same company you get your toner from. The PCU should generally be replaced every 60,000 copies, but sometimes it may need to be replaced sooner (especially if you run a lot of dark copies or make a lot of copies of images) and it can often run longer than 60,000.
Replacing the PCU is easy -- it sits right next to the toner bottle, and all you have to do is slide the old PCU out and slide the new PCU in (once you remove all of the tape and other trappings from it). Instructions will be included in the box with the new PCU.
Please rate the effectiveness of this solution. Thank you!
Oct 10, 2010 | Lanier 5222/27 Laser Printer
After changing toner on my sharp, SF-2022 copy machine, the copies are coming out with black smudge marks across the paper? how/where should i clean?
This means the machine is over-toning ie using more toner than required caused by either improper toner or different brand of toner. The correct toner is sf 222T1. Replace developer and use the right toner and clean the drum and its blade. You may need to clean fuser rollers for cleaner copies.
Nov 13, 2009 | Sharp Office Equipment & Supplies
Sharp SF-7320 produces grainy copies
Clean the drum unit seal blade thats leaking or replace it.
Nov 11, 2009 | Office Equipment & Supplies
The copies comes out totally black
H2 00 Thermistor open, your fusing unit needs to be serviced (cleaned or replaced)
The black copiers can be a number of things a few things to check and what the remedy could be;
  1. Open the right door, if you notice a lot of toner/developer spilt then you could be having a charge corona short (built onto the drum unit) clean corona
  2. Open the right door, if you drum (green or blue cylinder (depending on brand of drum) under your fuser) is coated with toner (should be all green/blue) then you could be having a drum short, replace drum unit for this.
  3. Open the right door and on the door towards the bottom is a metal unit with a white guide built on it (transfer corona) if there is a lot of toner/developer in it (looks dirty) then this needs to be cleaned or re-built.
  4. You also could be having a board issue causing the black copies.
Mar 26, 2009 | Sharp Office Equipment & Supplies
Our Gestetner DSm645 gives Dark Copies..........
Sounds to me like the drum needs replacing, and likely the developer too. There is probably a haze of toner still on the drum. You can check by opening the right side cover and looking at it. Is there toner on the drum (green cylinder). It may not be too obvious depending on how dark the copies are. GENTLY wipe a tissue across it after making several copies - it should be clean if the drum is functioning properly. If it is, it could be the fuser that is wearing out, but I'm leaning toward the drum. As I said, if you need to replace this, it is a good idea to do developer at the same time, because these machines tend to be a little sensitive.
Mar 18, 2009 | Office Equipment & Supplies
46 people viewed this question
Top Lanier Office Equipment & Supplies Experts
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
