Question about Allen & Heath Music
SOURCE: hi there my allen heath mixer is weired this
If you use analog outputs and inputs try to clear of it really is your mixer and not one of the inputs. If the inputs are good your mainboard could be a bit dusty or you have a loose contact. If you have a mixer with internal interface your audio stream from your computer might be the problem.
Posted on Mar 10, 2010
SOURCE: I have an allen and
Usually the connector that is board mounted is the problem. I would OPEN the unit as there may just be broken solder at the connector inside. If the connector requires replacement, find one at Digikey.com by searching for "power connector coaxial".
Hint: In the future install one of those little lamp switches that are in a little plastic box with knurled knob sticking out the sides. ONLY break ONE wire from the adapter to avoid getting the connections reversed. Since the wires are smaller than lamp cord, tack solder the wires to the piercing points of the switch .
Posted on Apr 11, 2011
Apr 07, 2016 | Allen & Heath Xone-22 2 Channel Dj Mixer
Jun 01, 2014 | Allen & Heath Xone:92 DJ Mixer
Mar 21, 2014 | Allen & Heath Xone:92 DJ Mixer
Nov 04, 2013 | Allen & Heath Xone:42 DJ Mixer
Oct 25, 2017 | Allen & Heath Xone-22 2 Channel Dj Mixer
Nov 03, 2011 | Allen & Heath PA28 Effects Mixer
Apr 11, 2011 | Allen & Heath Xone-22 2 Channel Dj Mixer
Feb 22, 2011 | Allen & Heath Allen and Heath GL2400-32...
Nov 13, 2010 | Allen & Heath Xone:92 DJ Mixer
Aug 27, 2009 | Allen & Heath Xone:92 DJ Mixer
61 people viewed this question
