The DC output for battery charging is from the engine alternator and is completely independent from the generator inverter.
As this is an inverter unit the typical polarization techniques for standard generators will not apply.
The ouput indicator being lit means the inverter input output should be good. This further implies a circuit disconnect state at the outlets. Try pressing the overload reset switch to make sure it is not in an odd state.
There are many proplems is Kipor generator. And if the generator has problem, you are the better to contact your supplier or engineers.
Here are some article for your reference: www.dieselgeneratortech.com
Oh, there are many people say the generator can not supply power. Maybe the fuel is not enough or other problems. I recommend you to buy diesel generator set in future, its quality is better and can use for a long time. A website for your reference: www.dieselgeneratortech.com
www.kipor.com/upload/spec2011061109073968.pdf P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
