Question about Vizio Televison & Video
What causes an intermittent problem with the main board on a vizio e500i-b1 50" LED TV?
I have a Vizio 50" tv which does not power up occasionally. I've tested the power supply board and ruled that out as the problem. I'd like to fix it-as opposed to replacing it- if possible. What could be causing the problem.
Russ Hill
  • Vizio Master
  • 4,057 Answers
It can be a processor fault, or software fault. check the manufactures web page for your model and see if there is an update for the software.
Posted on Jul 23, 2017
5 Related Answers
SOURCE: Vizio 42 in L42HDTV10A no power no lights no nothing
You can look at the various module failure symptoms and service / replacement options for the L42HDTV10A here:
http://www.coppelltvrepair.com/search?Q=l42hdtv10a&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
Posted on Apr 25, 2013
coz331
  • 30 Answers
SOURCE: How do I fix power issue with Vizio TV
Is this the same main board as yours as shown in this thread?
http://www.badcaps.net/forum/showthr...light=SV422XVT
There are two fuses and 3-pin voltage regulator ICs that need to be checked and report the result as shown in this thread:
http://www.badcaps.net/forum/showthr...999#post300999
__________________
Never stop learning
Basic LCD TV and Monitor troubleshooting guides.
http://www.badcaps.net/forum/showthr...956#post305956
Voltage Regulator (LDO) testing:
Inverter testing using old CFL:
http://www.badcaps.net/forum/showthr...er+testing+cfl
Tear down pictures : Hit the ">" Show Albums and stories" on the left side
http://s807.photobucket.com/user/budm/library/
TV Factory reset codes listing:
http://www.badcaps.net/forum/showthread.php?t=24809
Posted on Mar 11, 2016
gopakumarg43
  • 76823 Answers
SOURCE: Vizio LED TV model # e500i-b1. No sound picture. On light stays on. Not sure if it's the main board or the t-con board or another thing. Did the flashlight test and didn't see anything in the screen.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Aug 22, 2016
emissionwiz
Marvin
  • 85239 Answers
SOURCE: My Vizio mod E500i-B1 heard a pop and no picture or sound. Would replace main board be possible fix?
It sounds like a surface mounted capacitor blew out. Examine the main board and see if you can see the failed part, if you do then replace that board.
Posted on Dec 28, 2016
gopakumarg43
  • 76823 Answers
SOURCE: I replaced my LED board on my vizio tv and fixed my black screen issue. This was until today which was about 2 weeks after replacing the board. Is it possible my power supply board is bad?
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Feb 27, 2017
1helpful
Vizio E500i-b1 went dark, any ideas on what to check next?
You can change boards in your TV all day and it's most likely no going to fix this set. Have you ever had a set of miniature Christmas lights that seemed to work great then all a sudden none would light, either because a bulb burned out or fell out? There are 2 types of electrical circuit wirings, one is series the other parallel. In series like your LED backlights are wired in your TV there are about 8 button lamps per circuit that have a 24 volt DC supply serving each set as this TV has what's called local dimming, one of the lamps has opened up making that set not light up, the power supply has over voltage and over current protection for each supply if one lamp opens up they all go out and this is exactly what's happened in your TV, the power supply safety circuit is non discretional, if it detects an error it shuts down the entire backlight circuit giving you no backlights. As far as a break down on what fails 5% of the times it's the main board 5% its the power board and the other 90% of no backlight failures on this model TV comes from the backlights being bad. You can change just the one bad strip if you wish but it's advised to change them all. Good luck!
1helpful
I have a vizio model E500I-B1, SERIAL LTY6PLYQ5254714 that I'm having some issues with.. it seems to have intermittent back like issues. can anyone advise me where to start?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
I have a Vizio E500i-A1. I have backlights and sound but no picture. I have ordered and replaced the tcon, main board and power supply board. Still no picture. Any Idea what the problem is?
LCD TV-Vizio e500-bi backlight intermittent
Vizio e500i b1 black screen, no image
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
I have a VIZIO E500i-a0 and it has a section of the screen (lower 1/3rd) that shifts out of focus with a horizontal line dividing the top 2/3rds. when in focus, its a little darker than the top part.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Open Questions:
Televison & Video Logo
Top Vizio Televison & Video Experts
Ekse
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
