Question about Element Electronics Televison & Video
How do I program a replacement remote control for Element Electronics FLX-2610?
Purchased an Element Electronics replacement remote control for Element Electronics Model FLX-2610 LCD TV. Just putting batteries in does not work. What do I need to do so they will talk to each other?
Posted by Nora Leslie on
5 Related Answers
Anonymous
SOURCE: Element LCD TV FLX-3210
Try 004. That worked for me
Posted on Jan 02, 2008
Anonymous
  • 1077 Answers
SOURCE: Remote stopped working. Where can I get a new one?
Here's two places for your new remote:
http://www.remotes.com/store/element/flx3210.html
http://www.newremotecontrol.com/Mfrs/OtherBrands/Def/dyn_part_data.php?catnum=CC-FLX-32-021
Posted on May 10, 2009
Anonymous
  • 3 Answers
SOURCE: remote code for element electronics flx-2610
go to the element electronics web site www.elementelectronics.com they have posted a usb thumb drive patch... as of 8-12-2010 the links do not work but once you identify your model and which download you need you can go to the left and find the "Downloads" and find it there. I downloaded the file from there and unfortunatly it did not work (as of 8-12-2010) I did receive an e-mail from Element, after I called and told them that the link was not working, the e-mail file worked perfectly!
Posted on Aug 13, 2010
BElectric
DILLIGAF
  • 1140 Answers
SOURCE: element electronics tv model # flx - 2611b bad
Try ShopJimmy.com - they have a huge stock of TV parts. They are used but tested meaning they are usually much cheaper option and often have parts that are no longer available.
Power board: (verify correct part before ordering)
http://www.shopjimmy.com/polaroid-860-az0-mlt666amh-power-supply.htm
Picture of above part:
http://assets.shopjimmy.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/s/j/sj860az0mlt666amh.jpg
List of available parts for your TV:
http://www.shopjimmy.com/catalogsearch/result/index/?q=element+2611&stock=all
You should verify the part number from your original board before ordering and also visually check that the replacement part matches your original. The part number is usually on a barcode sticker on the board or printed on the board itself. Be careful here as the number on the board may be the board number so try the find a part number if possible - the same board can be used for various configurations of components so is not a guarantee of being the correct part. Also manufacturers sometimes use different boards in televisions with the same model number according to price/availabilty/reliability.
You can also verify stock, part number, etc by contacting the supplier first. They may also be able to help you if you can't find your part on their website.
http://www.shopjimmy.com/contacts
Alternatively, once you have identified the part number, search for other suppliers by entering the part number into Google or Google Product Search. Be sure to enter the part number with any hyphens, spaces or periods as it is written on the board and if you have no success, also try the same search without any punctuation, e.g just the numbers and letters with no spaces.
http://www.google.com/products
Hope this helps.
Regards,
BElectric
Posted on Nov 25, 2010
Ernest Barud
  • 73 Answers
SOURCE: Hello, I cannot power on my Element Electronics
Unplug it leave it unplugged for about 10mins. replug it in and turn it on. If that doesnt work. Your going to most likely need to change the fuse for the power current. IF your not sure how to do this find expert repair services near you. It is cheaper to buy a new tv unless you try to do it yourself and end up damaging more
Posted on May 02, 2011
Element FLX-2610 Red standby LED is lit, but will not turn on
The set will need to be serviced, but sounds like you have a problem with either the power supply or main board.
Oct 23, 2012 | Element Electronics FLX-2610 26 in. LCD...
Hello, I cannot power on my Element Electronics FLX-2610 26 in. HDTV LCD TV. I turned it off the regular way and the red light is on but I cannot turn it on. Any easy solutions?
Dec 18, 2010 | Element Electronics FLX-2610 26 in. LCD...
Need code for element tv to program dish network remote
Try this link it should give you the codes and instructions.
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Daniel Busa
DISH Network Customer Service
Dec 03, 2010 | Element Electronics FLX-2610 26 in. LCD...
FLX-2610 tv.Has always worked fine. Bought a new desktop todsy & hooked up tv as monitor.Now I can't get it out of standby. Changed batteries in remote but not getting response from on set controls...
Have you tried using the power button on the TV instead of using the remote?
This could be a stress or overheating issue on the TV. Try to power cycle the TV by unplugging the power cord from the wall outlet and leave it disconnected for about 30 minutes, then turn it back on.
If same problem occur, then it's the power supply board that have gone bad. For power supply board problem, It would be best to contact the manufacturer or a repair tech for second opinion.
Good luck and have a great day!
Jan 24, 2010 | Element Electronics FLX-2610 26 in. LCD...
Element FLX-2611B won't turn on. The red light is not lit
Just because fuses are intact does not mean it is not damaged. Sometimes a small spike of power does not blow a fuse but damages Transformer windings Before the fuse! If there are no lights picture or sound think powersupply transformer primary.
Aug 14, 2009 | Element Electronics FLX-2610 26 in. LCD...
Remote code for element electronics flx-2610
Jan 01, 2009 | Televison & Video
Televison & Video Logo
105 people viewed this question
Top Element Electronics Televison & Video Experts
Mike
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
