SOURCE: kenmore 10 stitch needle won't move
hi there,
push or pull hand wheel clutch to engage
motion of needle and shutter.
if not check belt on downside of hand
wheel open cover motor,loosen bolt cover
see belt check if engage on pulley by
holding hand wheel move belt if
hand wheel move,if not tighten screw on
pulley from hand wheel and moter.
have a nice day and thanks
SOURCE: Lights turn on but foot pedal stays dead. Needle
If you know someone who is savvy in the mysteries of electricity, ask them to test the foot pedal to see if it is working and the socket on the machine to see if it is receiving power.
If you need a new foot control pedal - check the Internet for best prices - you will need the machine's model number.
If you take the machine to a dealer for service, ask what it will cost before making the trip.
The bench rate for just looking at the machine may not be worth it.
SOURCE: Have Viking Husqvarna #1+ sewing machine that when
Make sure that the bobbin winder stop is up. That is the little black post below the bobbin winder. If it is pressed down, the machine will not run.
SOURCE: Singer 2259 - The machine has stopped moving, the
Check to see if you have your bobbin winder on. That's usually the problem. Just push it to the left and you should be ok.
SOURCE: The needle does not move when the foot pedal is used.
Make sure that you pushed the bobbin winder all the way to the left.
Jimmy
