Question about Sewing Machines
How to calm your dog down when It is thundering
Crying shaking
  • Sewing Machines Master
  • 12,731 Answers
Over the counter Benadryl (for people) will help calm your dog. Be sure to research the internet for the amount to give your dog based on its weight. We have an 85 lb dog that we give Benadryl because he has anxiety riding in the vehicle.
Posted on Jul 23, 2017
    Sergeant:
  • 293 Answers
I would ask your vet, for a mild sedative if the dog is in that much distress.
Kenmore Sewing Machine Model 385.16221 feed dog is stuck down,m the lever just does nothing. It lowered feed dog, then was useless when I went to raise it to position.
your machine will have a flip type opening at the very front of your machine above the area where the needles are attached to the arm that moves up and down ( it usually has the light globe installed in there ) after opening that door you will see where the dog feed is attached to it should also have a spring that helps the dog feed return to the up position when not in use , make sure it is not stuck in any way and some lubrication oil should be used to prevent it from sticking , while using the dog feed release button push the spring in a up and down motion to help it to dislodge
Oct 28, 2017 | Kenmore Sewing Machines
When the embroidery unit is on the machine the "the feed dogs are raised lower them" comes on when I go to the embroidery edit or embroidery on my lcd screen and the feed dogs are down.
The problem you've explained isn't totally clear. I'll try to give help on your problem.
On embroidery machines the feed dogs are suppose to be down while operating in the embroidery mode.
When you change programs to embroidery the sewing machine recognizes this mode and automatically makes the feed dogs go into the down position.
If you are attempting to operate embroidery and your feed dogs don't go under the plate then: Try the switch that is under the storage unit and switch it to free arm.
Aug 25, 2015 | Sewing Machines
Feed Dogs
when the feed dogs are in the up position the sewing machine
will sew
but when the feed dogs are down postion it will darn
try the feed dog lever again if you can move the feed dog lever and
the feed dogs respond going up and down then you know that
the feed dogs are working and are not broke
but if they do not respond then they need to be checked to see what's
wrong with them
Oct 23, 2012 | Sewing Machines
Feet not feeding and thread bunching up
the presser foot or what ever foot your sewing with does not feed the
fabric,, the feed dogs in the needle plate are what moves the fabric
to be sewed, the feet only hold the fabric against feed dog so the
machine can use the needle to sew the fabric.
if the fabric is not moving then the feed dogs have to be checked
can you see the feed dogs in the needle plate area are the up or
down?
do you have a manual for the machine?
a manual help to know where the feed dog lever is, I'm sending
you a link for a manual for the machine, so you can look for the feed
dog lever, if the feed dogs are up then there is something wrong
with the feed dogs & they need to be checked.
but if the feed dogs are down then look in the manual & see where
the feed dog lever is & put it in the up position & see if that brings
the feed dogs up to the sewing position, if the feed dogs do not
come up then the feed dogs need to be checked.
http://www.sewingpartsonline.com/instruction-manual-necchi-6015.aspx
Oct 16, 2012 | Necchi 6015 Mechanical Sewing Machine
I put the feed dogs down and now they won't go back up, what do I do now?
The feed dogs are driven by the feed driver mechanism, turn the hand-wheel forward and the feed dogs will come up. (Providing you have the feed dog switch to the up position).
Feb 11, 2012 | Baby Lock Ellure
Raise feed dog
I have a different model Viking with a feed dog button to the left of the power button. When it's pressed down, the feed dog stays in the "down" position. Press it again to bring the feed dog up.
May 19, 2010 | Husqvarna Viking 1
I have a Janome MYECEL 18W limited Ed. Put dogs
When you lower the feed dogs on this machine and then flip the lever back for the feed to come up again, the machine must turn a couple of turns to get the fedd up.
Mar 11, 2010 | Sewing Machines
Feed dogs stuck in down position
The feed dogs come up as soon as you start sewing again. Just make sure they're in the up position and start sewing.
Sep 19, 2009 | Brother SE-270D Computerized Sewing...
Broken needle
Remove the needle plate and Turn the machine upside down and shake it or just leave it alone. It will not get into your gears. If you can see the needle you can take it out with some tweezers.
sewman7
Jun 17, 2008 | Brother Sewing Machines
Feed dog is stuck
I have the same problem...this is a work around, not a fix. You need a small flat-head screwdriver. 1. Remove the clear bobbin cover. 2. Make sure the feed dog switch is in the DOWN position. 3. Slide the screwdriver under the feeddogs from inside the bobbin area & lift the feed dogs. 4. While holding the feed dogs in the up position, return the feed dog knob to the up position. You have to do this every time you put the feed dogs down...bummer, but I can find no broken part or adjustment that corrects this. If it's inside the machine body, I don't mess with it... I did take off the bottom plate in the feed dog area..one screw holds it.... there is nothing there to indicate a problem.
May 07, 2007 | Singer 2662
Sewing Machines Logo
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
