Question about CorningWare Crock Pots & Slow Cookers
Need P-35-B replacement cord for corningware warming tray
Posted by Wanda stubinski on
1 Related Answer
ellenskitche
  • 62 Answers
SOURCE: NEED ELECTIRC CORD FOR A CORNINGWARE WARMER TRAY
Check the cord choices at this site, and you may find aht you need at a reduced cost:
http://nelsonappliance.com/Appliance%20Cords.html
Posted on Nov 26, 2009
Can I replace cord on Corningware cooker.
Yes you should be able to replace this cord.
Start by a/ Getting the size of cord required, is it 1.5 or 2.5mm conductor size. Check the manufacturers rating plate to see wattage/power rating of the cooker.
b/ Check the cord, is it heat resisting type??
c/ Cut a piece off and take it to local diy electrical shop to get correct rating and type.
d/ ALWAYS SWITCH OFF BEFORE CHECKING ANYTHING.
Dec 01, 2014 | CorningWare Crock Pots & Slow Cookers
I need a replacement lid for my Corningware SC 60 can anyone help me with this
Try these folks:
http://www.classickitchensandmore.com/contact_us.html
Classic Kitchens And More
2406 N. Sherman St.
York PA 17406-2305
[email protected]
(717) 840-9537 (please call during store hours)
Store hours are Friday & Saturday 10-6 and Sunday 12-5. Other hours by chance or appointment.
Also you can contact CorningWare here to locate a source for your replacement lid:
http://www.corningware.com/index.asp?pageId=83
If that page does not work use this link and click on contact us rt side of the page 3/4 of the way down.
Thanks for choosing FixYa.
Kelly
Sep 18, 2010 | CorningWare SC60 Slow Cooker
Nov 15, 2009 | Crock Pots & Slow Cookers
NEED A REPLACEMENT GLASS LID FOR CORNINGWARE SC-60 SLOW COOKERW
I have this item if you want, I can send it to you. My slow cooker no longer works.
May 27, 2009 | CorningWare SC60 Slow Cooker
The 4 position switch dial is broken. I would like another
this is not a replaceable part . thats why you cannot find it . the base is made in china and only imported as a finshed unit , there are no parts in the usa
Feb 20, 2009 | CorningWare SC60 Slow Cooker
Broken crock on Corningware Electrics
I have a Corningware 14 speed electric bklender and I need a new lid for it. I do not need the measuring device. Where can I obtain this item?
Nov 03, 2008 | Rival 38651-C 6-Quart
Corningware k4903 slow cooker
I had the same problem and I had to ask my wife. You must first select the cook time (button on left). The more time you select, the higher the mode (warm, medium, high). Then you turn the unit on. I guess the unit calculates which mode based on the amount of time you select in step one.
Not nearly as intuitive as it should be.
Sep 01, 2008 | CorningWare K4903 Slow Cooker
Corningware slow cooker 6qt
If you choose the auto selection the slow cooker will cook for three hours on high then will automatically reduce to the low setting.
Aug 22, 2008 | Crock Pots & Slow Cookers
Crock Pots & Slow Cookers Logo
133 people viewed this question
Top CorningWare Crock Pots & Slow Cookers Experts
gbob59
Marvin
Marvin
NOEL
NOEL
Are you a CorningWare Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
