Question about Lexmark Office Equipment & Supplies
Good morning! I have a Lexmark 5470 printer! It has both black and coloured ink new but over one year old due to other computer issues. Error 1203 keeps cropping up. Why?
Posted by william davies on
5 Related Answers
Anonymous
  • 624 Answers
SOURCE: Error #1203
Normi, The 1203 error as you suspected deals with the ink cartridge. This is a common problem and Lexmark has a troubleshooting procedure posted on their web site. Here is the link for the web page. http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&emeaframe=&docid=ENUS21870 Hope this solves your problem and please don?t forget to rate this posting.
Posted on Jan 20, 2007
Anonymous
  • 5 Answers
SOURCE: x4270 lexmark all-in-one InkJet Printer
Error 1203 is a bit of a generic cartridge issue. If this is a new printer and these are new cartridges, the most likely cause is defective cartridges, they do happen from time to time with new printers. It is also possible that there's a communication issue in the cartridge bay in your printer. Personally, I wouldn't try to do these diagnosing steps (Short of checking for any obvious mistakes). Since this printer is brand new, I would put it back in the box and return it for an immediate replacement. Some retailers would try to find any way to discredit your return right, the aim would be to give them as little ammunition as possible. To try and self troubleshoot the cartridge, first make sure they are inserted correctly. First, ensure you removed the tape from the contacts on the cartridge from its package. Make sure when you snap the cartridge in, it doesn't appear loose or easy to shake in the cradle. If you're still getting the error, remove the cartridge and check for any residual ink. If ink is present (appearing to leak in any form), it's possible this is causing the error. You can try cleaning the cartridge, a safe solution to use would be a light application of methylated spirits on a cloth that doesn't disintegrate. Holding the cartridge at its sides, you can run the cartridge in a vertical motion on the cloth. Horizontal motions can potentially damage the cartridge. You can also check the contacts on the printer (This is, the gold circuits where the cartridge touches the printer in the cradle). If ink appears on this, this can also be causing the issue. You would need to use an electrical safe contact cleaner (A very light amount) and a safe cloth to clean it with. Anything that can leave particles would be unsafe to use. Make sure to let the solution dry before reinserting the cartridge. Hope everything works out.
Posted on Jan 24, 2007
Chris Schutte
  • 51 Answers
SOURCE: help - Black not printing
Try cleaning the contact points of the cartridge itself and the unit that holds the cartridge with alchol. If still not printing try nossle cleaning from your printer properties.
Posted on Mar 27, 2008
Anonymous
  • 28 Answers
SOURCE: Replaced colour cartridge and got error 1203
Power off the All-In-One (AIO) and remove the power supply fromthe back of the unit. Wait 30 seconds, then reinsert thepower supply and power the AIO on.
Did the error message return?
Yes:Continue to Step 2.
No: Print a test page. If the test page prints, the error is resolved.2 Open the top cover of the AIO and remove bothcartridges from the AIO. 3
Power off the AIO and remove the power supply from the back of theunit. Wait 30 seconds, then reinsert the power supply andpower the AIO on.
Yes:There is a hardware problem with the printer. Continue to ContactingLexmark below.
No: Continue to Step 4.4
Power off the AIO and remove the power supply from the back of theunit. Reinsert the power supply and power the AIO on. Open thetop cover of the AIO and insert the color cartridge. Close thetop cover.
Yes:Continue to Cleaning the Cartridge Contacts, thenrepeat Step 4. If you have already tried cleaning the contacts,continue to Checking the Cartridge.
No:Continue to Step 5.5
Power off the AIO and remove the power supply from the back of theunit. Reinsert the power supply and power the AIO on. Open thetop cover of the AIO and insert the black/photo cartridge. Close the top cover.
Yes:Continue to Cleaning the Cartridge Contacts, thenrepeat Step 5. If you have already tried cleaning the contacts,skip to Checking the Cartridge.
No:Print a test page. If the test page prints, the error isresolved.
Posted on Nov 12, 2008
vegakitten20
Juanita Vega
  • 685 Answers
SOURCE: Lexmark x2650 printer not responding to new cartridge
yes you have to have both of them then everything should be fine.if you have the color cartridge that is empty put it in for now and see if it will work it will let u know that it is empty but at least you will be able to print in black
Posted on Jan 04, 2009
My Lexmark prevail pro 705 has stopped printing anything colour even after i have replaced all the cartridges??
This article on How to Troubleshoot the Vizix Ink Technology will help fix print quality problems on your printer. To run the Deep Clean Printhead function on your printer -> on the printer operator panel, press Setup -> Maintenance -> select Deep Clean Printhead. Your printer will then print the test page. Hope this helps. Thanks.
Jan 11, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
Lexmark x1270 won't print in colour
There is nothing wroung with refilling but there is something wroung with the cartridge if it does not print. You might have ran out of refill cycles on that particular cartridge and not even know about the cycle requirments for lexmark printers. Your issue could be resolved by purchasing a new cartridge fixing the old one is not going to cut it.
Thanks and please do rate your experience with my solution.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jan 22, 2010 | Lexmark X1270 All-In-One InkJet Printer
Printer is refusing to print colour, with full colour ink tank.
Have you checked the ink levels in your cartridges? Ink can dry due to usage and also due to prolonged non usage.
Apr 13, 2009 | HP LaserJet 1100 Printer
Lexmark 5470 printer not working on Windows Vista
If you just connected the printer to your Vista PC, the drivers probably didn't load.
If you haven't yet, you need to install the Lexmark drivers first before you can use your printer. Unplug the printer before installing, then plug it in when prompted by the software.
Lexmark drivers:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Mar 24, 2009 | Lexmark X5470 All-In-One InkJet Printer
Refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Jan 08, 2009 | Lexmark X5150 All-In-One InkJet Printer
No color 5470
HELLO FIXYA..
THE FIX WAS TO UN-IN-STALL THE (5470) SOFTWARE AND RE-IN- STALL. I COULD MAKE COPIES FROM THE COPIER BUT NOT FROM COMPUTER(BLACK OR COLOR).THE COLOR PROBLEM APPEARS TO BE THE INK CARTRIDGES
I DO NOT KNOW IF THE PROBLEM WAS WITH THE SOFTWARE (CD) THAT WAS SENT WITH PRINTER OR IF I CAUSED THE TROUBLE MYSELF.
I WILL OBTAIN NEW INK CARTRIDGES TOMORROW AND CHECK THAT PORTION OF TROUBLE
IF IT DOES NOT CLEAR THE COLOR PROBLEM UP,I WILL UPDATE YOU..
THANKS FOR YOUR CONCERN,
BGC
PS I RECEIVED SOME GOOD HELP FROM LEXMARK SUPPORT CENTER ALTHOUGH I HAD TROUBLE UNDERSTANDING HIM. HE WAS VERY KNOWLEDGEABLE.
1-800-3324120
Nov 24, 2008 | Lexmark X5470 All-In-One InkJet Printer
Incorrect ink level reading
kiwipom, While ink cartridges look like plastic cups that only hold ink...they are not. The information the printer needs to think it has a "NEW" set of ink cartridges is on the cartridge itself. You must fakeout the printer to believe you are inserting "new lexmark" inks. Printer companies make money from the repeated sale of the ink, not the printer itself. I had an old epson that I would refill I would then have to place pieces of tape on the cartridge turn the printer on, remove the cartridge move the tape to another side of the cartridge turn on again etc. Anyway lexmark may need the same. When the new original cartridges show try them first to get the printer "thinking" correctly. Let me know what happens. Good Luck, Tim
Feb 27, 2007 | Lexmark X7350 All-In-One InkJet Printer
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
