Refrigerators Logo
Question about U-Line Refrigerators
We have a U-Line mini fridge with ice maker. 1 month old and 1 week ago it started making "working too hard" noises. 1 week ago we had paused the ice making function. Related ?
Posted by amy saltzman on
brokenrubber
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 103 Answers
ICE CUBES IN ICE MAKER HAVE LIKLEY SHRUNK
AND ARE NOW JAMMED IN ICE MAKER INSTEAD OF FALLING OUT
CHECK THE ICE MAKER FOR JAMMED CUBE
Posted on Jul 21, 2017
5 Related Answers
Anonymous
  • 1314 Answers
SOURCE: Ice maker not making ice
this is from another post i did but will cover you too your ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure yuo hold the plastic insulation so you don't get bit if the ice maker starts cycleing remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didnt fill replace the water valves if the icemaker doesnt cycle and yuo may have to kinda twistm the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Posted on Jan 19, 2008
Anonymous
  • 65 Answers
SOURCE: Ice maker stopped working
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
Posted on Feb 16, 2008
Anonymous
  • 45 Answers
SOURCE: Ice Maker Problem Question
take the ice bin out look in the hole at the ice maker you may have a ice cube stuck between the tines of the ice maker if not look at tines somtimes they get crossed up if not that feel in the ice maker does it have water or ice in the maker? also there is a on off switch on the side of the ice maker make sure it is on, you will also see the white ice level arm you can move it up and down it is about 8 in long make sure it is free to move
Posted on May 22, 2008
Anonymous
  • 489 Answers
SOURCE: Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Posted on Sep 30, 2008
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: our Samsung ice maker stopped working
Sound like the problem may be a gear broken or damaged in the module which appears to be replaceable in your model. If you can dissasemble it enough to inspect the gears you may can replace the part instead of the entire ice maker. It looks like the motor may be in part 18 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=RS2630WW&productCategoryId=0165000&brandId=1482&modelName=SAMSUNG-REFRIGERATION&diagramPageId=00009&componentDescription=ICE%20MAKER&documentId=M0612092&backToLink=Return%20to%20Sub%20Components%20list
Posted on Sep 09, 2009
Ice maker topped working, fridge is only 3 months old
Need Make and Model Numbers...some possibilities
1. shut off level on ice make in up position
2. no water ( I've seen where cats have chewed water line )
3. Bad ice maker
Ice maker in not working
A lot of times the reason the ice maker is not working is 1 of 2 things. First I would check the water filter if the fridge has one, and make sure it is new, or replace it if it has been over 3 months (depending on the fridge and filter, could last longer). If you replace the filter and the ice maker is still not working, be sure to check the water line going into the fridge, if it is a plastic line (soft to the touch) make sure to squeeze it ever so gently to see if water is flowing through the line properly. If so then, you may need to turn the water off to the fridge and disconnect the water line from the fridge to see if it is clogged, if so it could be clogged with calcium deposits, if not then the mechanism for the ice maker it's self could have gone out and needs replaced. This all depends as well on how old the fridge is. If the ice maker has a metal bar, be sure it is in the proper position to make ice, a lot of times they get broken and need replaced.
The water dispenser is not putting out water and ice maker is not making ice. The fridge frequently cycles like it is trying to send out water.
it's still under warranty for up to 1 year,call whoever you bought it from and it should be repaired free of charge and next time you write send model number.
Refrigerator intermittent humming sound
If it's not causing any problems to the overall operation of the unit itself, I wouldn't worry about it.
Our Samsung ice maker stopped working
My whirlpool aide by side fridge icemaker is making buzzing or humming noise
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your ice maker is making a buzzing or humming noise ice maker isn't making much ice. . fridge is about 2 1/2 years old.
This sounds like a clogged water line or a electrical short !
I would get service rather than take a chance on electrical fire.
Or burn up the circuit in the ice maker.
Thank you for giving us the opportunity to advise you.
Huuum
Please remember to leave a rating before you leave us
Please remember to leave a rating before you go!
Thank you
1helpful
Several problems with ice maker
i suspect he real problem is that the freezer is not defrosting. its difficult but take off thge back panel in the freezer and see if there is ice build-up on the pipework behind.if so melt it off with a hair-dryer and check also that the drain is clear. the water you have had on the floor could be due to intermittant defrosting
Top U-Line Refrigerators Experts
Marvin
Marvin
W.L.
Kardoc
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
