Question about Air Air Purifiers
Try placing the filter in again. Also unplug the unit an wait a few seconds to reset. Plug it back in. I am guessing you got wrong filter or it is not placed in correctly.
Posted on Jul 20, 2017
Testimonial: "no I already did that 3 times. You just have to push the on button right. Is there a reset button?Reusing the same filter I took out."
SOURCE: Sharper Image GP Silent Air Purifier with Ionic Breeze s1730
i have 2 units, and had this same issue happen 3 times. Tonight it happened with a forth, last time i had to talk to management to get it replaced outside of warranty. Ionic breeze has major quality issues, and I would NOT buy anything else from sharper image. They also reduced the warranty from the original model drastically. for the price these were, they should be covered lifetime to show their commitment to their product. there is also a class action lawsuit against sharper image, for their false claims for the product...i believe sharper image chose to settle.
Posted on May 31, 2008
SOURCE: kenmore air purifier- model 85500
Power Off the unit then Press and HOLD the Off-Timer and Function buttons at the same time WHILE Powering the unit back On. The Replace Filter light will blink for 5 seconds than go out. Now you can release the the buttons.
Just to make sure everything is working fine power off and on the unit.
On a side note if you are a tight wad like me you may want to just smak the filter layers against the ground a few times to clean them and re-use them / make them last longer. When the replace fileter light comes on too often then it is time to replace the filter.
No worries ;o)
CDA
Posted on Nov 16, 2008
SOURCE: Filter light doesn't turn off after replacing filter.
Thank you!! Yes, this does work
Posted on Mar 31, 2009
SOURCE: I have 2 ionic breeze air purifiers sharper image.(germical )
I have the same problem as gerardperez7. One of my germicidal light quadras won't turn the light on and doesn't appear to be cleaning the air at all. I even put a new light bulb in it and it doesn't fix the problem.
Posted on Dec 22, 2009
SOURCE: I have a 'homedics AR
Hi, I had the same problem until I realized that the bottom is the clean filter indicator just press it down with something and it will beep. I hope it help.
Posted on Sep 24, 2011
