SOURCE: hitachi cle-990
not sure your model number is correct please check here is a manual for the 42 CL plasma TV http://www.hitachiserviceeu.com/scripts/userguide.php/CL42PD2100_EN.pdf if it is a different set please check the model number, this should have a 42 in it (as it is 42")
SOURCE: hitachi remote CLE-967
Hi.
I wrote an article on how to repair remote controls.
You will find it here.
http://www.ehow.com/how_2094701_tvvcrcabledvd-remote-control-quick-easy.html
Chris.
SOURCE: Enter channel number of double digits?
Are you being serious? Are there numbers on the remote? press 02 for channel two press 08 for channel eight press 10 for channel ten all the way up to 99 then back again.
SOURCE: manual tuning of Hitachi cle-942 tv
Select the channel to tune & press "CH" this is the key to the right of zero on the CLE-942 remote, Now you can tune the selected channel. You also need this key to sort/move channels after running auto tune.
SOURCE: I have a remote to a hitachi 42 inch plasma TV
You can check on ebay for this. They have many different options. You can also get a universal remote for the TV. If you buy one that learns, you can use a remote from Best Buy or somewhere that has the remote you are looking for.
http://www.42televisions.net
