Question about Kenmore Ovens
SOURCE: Electric Kenmore Ultra Bake Oven
I finally found my manual to the range, and to change from celsius to fahrenheit press the BROIL button for 5 seconds. A tone will sound, and the temperature should switch to Fahrenheit.
As far as the code PF 5ab--it could be PF Sab which means the power went out during Sabbath mode. Try pressing and holding TIMER OFF for 5 seconds. If that doesn't work, then open the oven door, press STOP/CLEAR, press both the HOUR "up" and "down" arrow pad at the same time and hold for 5 seconds, "Sab OFF" should appear. Press START to accept the change, then close the oven door.
Posted on Sep 17, 2008
SOURCE: I have a Kenmore Ultra Bake Stove, we had a power
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Posted on Feb 15, 2010
