In the past month, objects are "smearing" horizontally across the screen, regardless of display colour. Is my monitor getting to the end of its life, or should I take it in for repair? Thank you!
Hello!
Please check the "troubleshooting" of the manual - hope it will help :) http://manualsbrain.com/en/manuals/1136151/?page=25
SOURCE: monitor
I would check the cable and connector pins first. Then I would suspect there's a problem with the video signal board inside the monitor. It could be the LCD panel controls, too. That would make the unit beyond economical repair unless you got a used one.
SOURCE: thin white horizontal lines across top of TV
replace vertical out put ic and related capacitors
please refer to a qualified tv personal to check tv
SOURCE: Picture horizontal lines!!
try call sony get one time warranty.maybe lcd panel bad or call bestbuy in home service
SOURCE: sony KP-43T75 color repair
I've had a convergence issue with my KP-43T75 and recently the TV made a "pop" noise and the picture+sound went out. The standby light repeatedly blinks twice over and over. Holding power button on startup causes a long blink, then the double blinks start and repeat.
I understandthat replacing the entire G Board (A-1316-471-A) will replace both problems but I can't find the part in stock, though I've seen it listed for $200. Any leads?
