Question about American Tourister 25-inch Expandable Rolling Upright Deep blue
My American Tourista luggage, bought this March, has blown a tire. The wheel seems fin but one of the tires has shredded. Can I get the tire replaced ?
Posted by Toni Ellis on
Don A
  • 2,770 Answers
Service Repairs American Tourister
Check local luggage repair shops.
Posted on Sep 10, 2017
5 Related Answers
Anonymous
  • 60 Answers
SOURCE: do I need to replace all tires on peg perego john deere
Hi!
On these, only the 2 rear wheels are the gear wheels. You will just need to replace the tires on those with the rubber ones if you choose to go that way.  Good luck!
Posted on Mar 11, 2009
stephensaon_
Rob Stephenson
  • 284 Answers
SOURCE: recomende tire pressure touring motorcycle
Generally I put the front and rear tires @ 40 psi. You get better gas mileage , plus it rolls better when you have to push it around, but you also get better tire wear. I would set your rear air suspension around 12 -15 psi.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_5bac37c3cb991fdb
Posted on Jun 11, 2009
Anonymous
  • 4 Answers
SOURCE: 19" FACTORY TOYO TIRES SHREDDING
Toyo®, Exclusive Tire of 2008 Toyota Highlander Hybrid, Limited Grade
September 20, 2007– CYPRESS, CALIFORNIA – Toyo Tire (U.S.A.) Corporation announced today that the Toyo® Open Country® A20 is the exclusive tire of Toyota’s all-new 2008 Highlander Hybrid, Limited grade. In addition, the Open Country® A20 is original equipment on several other models of the 2008 Toyota Highlander, both hybrid and gas.
The Open Country A20 achieved exceptional low rolling resistance performance making it ideal for the hybrid model. The tires were also specifically designed to reduce noise and improve both wet and dry braking for added safety.
Based on the model and trim level of the Highlander, the Open Country A20 comes in two sizes: P245/65R17 105S and P245/55R19 103S.
Toyo manufactures and distributes a complete line of replacement tires for high performance cars, luxury vehicles, light trucks and SUVs as well as tires for commercial trucks, buses and off-road and construction applications.
I'm surprised if it's so good at braking that it has not ripped my entire tire tread off as technicians say the treat is separating well before its time!
Posted on Aug 09, 2009
mike fuson
  • 636 Answers
SOURCE: my front end shakes when i hit a bump at 50 mph, the front tires
could be a bent rim ? have you changed the universal joints? how about the tie rods and stabilizer bar
Posted on Aug 13, 2009
Testimonial: "thank you very much, i will do this first thing. i have had several people look at it , and of course they have told me it was not the tie rods,i knew"
Anonymous
  • 206 Answers
SOURCE: spare tire tools
From the owner's manual for that model, see link below also, page 299 of the PDF has a nice picture.
Spare Tire Removal
Fit the jack handle extension over the drive nut. Use the
Lug Wrench to rotate the nut counter clockwise until the
spare is on the ground with enough slack in the cable to
allow to pull the tire out from under the vehicle.
CAUTION!
The winch mechanism is designed for use with the
jack extension tube only. Use of an air wrench or
other power tools is not recommended and can
damage the winch.
When the spare is clear, tilt the retainer at the end of the
cable and pull it through the center of the wheel.
http://www.jeep.com/en/owners/manuals/index.html?year=2006&nameplate=Grand%20Cherokee
Posted on Oct 05, 2009
I have a 2005 Buick terraza (similar to uplander/sv6/relay) and I find I go through a set of tires every season. It's ridiculous. My tires are balanced, my alignment has been checked again and again...
take you vehicle to a good service center. you may have a camber that is off or your frame may be bent. causing your thrust angle to be wrong trashing you tires. is it all 4 tires and is there a side that the tries wear on.
Aug 21, 2014 | Cars & Trucks
19" tires shredding side closest to car 24K on tires
I have not heard of any and talked tothe dealer said it was a under warrenty. struts normally don't wear out for a long time.
Aug 14, 2009 | 2008 Toyota Highlander
Shredding tires on 2008 Highlander.
better have wheel alignment checked so it won't happen again
Jul 24, 2009 | 2008 Toyota Highlander
Do I need to replace all tires on peg perego john deere
Hi!
Jan 13, 2009 | Peg Perego John Deere Gator HPX Ride on...
American Tourister 25-inch Expandable Rolling Upright Deep blue Logo
704 people viewed this question
Top American Tourister Luggage & Travel Experts
Tom Chichester
ray gallant
MODERATOR Canada
MODERATOR Canada
Are you an American Tourister Luggage and Travel Expert? Answer questions, earn points and help others
