Question about Springfield Measuring Tools & Sensors
My. Springfield precise temp wireless digital outdoor thermometer model 91455 SF reads LL.L for outdoor temp. It starts with a temp and in minute reverts to on the LL.L. It is a new device.
Posted by Robert Wagner on
5 Related Answers
Anonymous
SOURCE: model 6312026 Nexxtech 433MHz wireless
Hello, you have to push few second the mode button and after date, hour etc it will be possible to change F for Celsius. He will flashing and after push one of the two button up or down.
Bye from Quebec Canada
Posted on Nov 20, 2008
sildejyt
SOURCE: how do i set up
Hi, First check the both channel of clock and thermometer (you can see the controler in battery insertion of thermometer and you can set up channel by pressing ch button on the clock)
Next press F/C search button until the clock find thermometer and press F/C search button again.
Posted on Nov 28, 2010
fixya-surfer
Sys Admin
  • 73 Answers
SOURCE: Acu-Rite indoor outdoor thermometer (model 00754)
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - Q: My wireless weather station periodically beeps, why?
A: Make sure that any alert and/or alarm features are deactivated first. Constant, sporadic beeping is generally due to the unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. Wireless devices that may cause beeping but are not limited to these devices are; scanners; computers w/wireless keyboard/mouse; or other wireless weather instruments. Essentially, any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
Another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. ALL good now.
Posted on Mar 02, 2011
fixya-surfer
Sys Admin
  • 73 Answers
SOURCE: Acu-Rite indoor outdoor thermometer won't stop periodic beeping
found solution - search for - Q: My wireless weather station periodically beeps, why?
A: .. unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. .. any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
There is no way to turn off beeping, d/s designers forgot. I had the same problem, another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. Don't use any sound features, ALL good now.
Anonymous
SOURCE: GE Digital Wireless Thermometer
Wireless Digital Thermometer GE5805WS4
Instruction Manual
Buttons and Functions
Button Function
Front of unit:
Min/Max...........displays Min or Max temps recorded
CH(Channel)......changes displayed channel
(hold 3 sec to erase)
Clear................clears memory in Min/max display
Back of unit:
C/F....................Toggle between Celsius
or Fahrenheit temperature display
Scroll.................Remote Channel Scrolling ON/OFF
INSTALLING BATTERIES
IMPORTANT:Read the section SETTING UP THE THERMOMETER before installing the batteries for the first time.
1.Remove the rear cover of thermometer. Install 2 new AA batteries. Replace battery cover.
2.Loosen 4 screws on rear battery cover of the Remote Sensor and slide battery cover off.
3.Install 2 new AA batteries .
4.After batteries are installed, the remote sensor will begin transmitting and automatically register to the Thermometer
(within range) after several minutes. However, you can also press the small button in the battery compartment (labeled Tx) to register the Remote Sensor to the Thermometer immediately
5.Replace battery cover and tighten 4 battery screws. Make ure that the battery cover is fully on and tightened to assure a watertight seal.
The thermometer can monitor up to two different Remote Sensors on two separate channels. Add-on remote sensors can be purchased separately and are compatible with the GE Wireless Thermometer/Clock (model GE5805WS4) as well as this unit. When first installing, always insert batteries into the Thermometer first, then into the Remote Sensor.
The thermometer uses random security code technology-it will learn the random code of the first Remote Sensor it detects and log in as channel 1. Channel 2 will register in the same way. NOTE: Registered channels will be erased when the batteries of the Thermometer or Remote Sensor are removed. When replacing batteries for a Remote Sensor, remember to clear the corresponding channel of the Thermometer in this way:
1.Remove batteries from the remote sensor (step 2 of installing batterie)
2.Select the channel that you would like to clear by pressing the CH button on the Thermometer until this channel number is displayed.
3.Hold the CH button for 3 seconds to clear the channel
4.Follow steps 3-5
MOUNTING THE REMOTE SENSOR AND THERMOMETER
Remote Sensor is suitable for outdoor mounting (watertight) at a range up to 100 feet from the Thermometer. HOWEVER, HE UNIT SHOULD NOT BE MOUNTED IN A POSITiON WHERE IT WILL BE SUBMERSED IN WATER, OR EXPOSED TO DIRECT SUNLIGHT, OR NEAR OTHER SOURCES OF HEAT OR COLD (I won't bother typing the rest) except for:
LOW Battery icon for the sensor will show up on either the
ch 1 or ch 2 display depending on which sensor is losing battery power.
Battery life 6 months
Temp Range Therm 32 to 122 deg F
Remote Sensor -58 to 158 deg F *
*Alkaline batteries can freeze temporarily at temps below -4 deg F. In this condition, the Remote Sensor cannot accurately transmit temp info to the Thermometer. This limits the effective minimum temp fo the Remote Sensor to -4 deg F
Operational Range....>50ft(and up to 100ft)(less interferances)
RF Channel ....refresh to "---" if no signal received in 60 minutes
Posted on Mar 21, 2011
What happens if two digital thermometers are set on the same channel
The same as when you have two radio stations on the same channel or frequency. The receiver wants so receive them both, resulting in a scrambled and useless signal in the receiver.
It won't work.
If the system can work with more than one (wireless) thermometer each will have an own channel number. and you will have to switch on the display to read one or the other.
Jan 05, 2015 | Springfield 91455 Wireless Digital Outdoor...
Springfield precise temp in out thermometer 91756
Return it to the manufacturer for warranty repair/replacement
Jul 23, 2014 | Taylor 91756 Wireless Thermometer With...
Springfield precise temp # 91455 reads LL.L on the outside temp gauge.
"L" is probly for low... try replacing the sensor component
Sep 19, 2013 | Computers & Internet
Instructions for springfield precise temp model 91455
I also reset my 91455 today. Go online to Springfield precise temp manual 91455
May 29, 2012 | Springfield 91455 Wireless Digital Outdoor...
My model is 91756 and i need to buy a remote sensor wire in Mpls mn
After 3 months and 4 emails to Springfield they finally responded and told me to buy my probe on Amazon. I can't find one on Amazon, do you have any suggestions or know of where I can purchase one?
Nov 17, 2010 | Springfield 91455 Wireless Digital Outdoor...
Measuring Tools & Sensors Logo
500 people viewed this question
Top Springfield Measuring Tools & Sensors Experts
Harrie
Andrew Taylor
Andrew Taylor
Are you a Springfield Measuring Tool and Sensor Expert? Answer questions, earn points and help others
