Question about Lanier Office Equipment & Supplies
Lanier Ld035 Copier: I cleaned drum then got error SC819 6261 0x64206469. how to reset or clear this error.
Posted by BRE Rive on
5 Related Answers
Anonymous
  • 78 Answers
SOURCE: Lanier ld145 duplex error
The duplex is on the right hand side of the copier (external unit from the main print engine). You firstly need to check for a jam inside the unit, open the unit away from the copier and there will be a blue tab to access further beyond the black plates. Also make sure the unit is seated correctly and plugged in (Turn off unplug and plug back in, this will also reboot the machine). This is customer recoverable error so the reboot should fix it
Posted on Jan 03, 2009
Anonymous
SOURCE: Lanier LD225 Drum Reset
There is a small "flag gear" on the back that needs to be in the "up" position to contact the button on machine and initiate it when it is installed
Posted on Feb 19, 2009
Everett Lin
  • 990 Answers
SOURCE: service code 561 error
Hello sir; Just follow my direction, it will reset your machine;
1, press "clear mode", "107", then press and hold down "clear/stop" key.
2, touch "copier SP" on the screen.
3, enter "5810-001" press enter.
4, set value to 0, then turn power off and back on again.
Posted on May 15, 2009
Anonymous
SOURCE: Lanier LD245 error code SC542 appears
Fuser warm up error. Code can only be reset in service mode after the problem is fixed
Posted on Jun 08, 2009
Anonymous
SOURCE: error SC101 on copier
No, you can't reset. You'll need a tech. Here's what the manual says: Symptom (SC101) - Exposure lamp error - The standard white level was not detected properly when scanning the white plate. Possible Cause: ? Exposure lamp defective ? Lamp stabilizer defective ? Exposure lamp connector defective ? Standard white plate dirty ? Scanner mirror or scanner lens out of position or dirty ? SBU defective
Posted on Jun 11, 2009
Lanier copier 5613 Error Code 549 What is it and how do I reset?
SP 5-810, press 1 hold down OK and original type key at same time to reset. -Carl
Nov 21, 2014 | Lanier 5612 Fuser Spring For Picker Finger...
How do you set the Lanier LD035 duplex unit?
Metal tab on right side of copier is bent and correctly touching the duplex unit interlock switch. Open the duplexer and notice the metal tab stick out. Put back to a 90 degree angle.
Jul 30, 2014 | Lanier Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Lanier 5635 error code displaying a SC320
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
Oct 15, 2010 | Lanier 5222/27 Laser Printer
Lanier Model #7320 Copier SN 826255. Has a wrench
Press "clear/stop" and "8" at the same time. An error code will be displayed in the copy quantity window as long as those two button are held down. What is the error code? Each code is specific to different areas of the copier. I will be more than happy to assist you in resolving.
Sep 23, 2009 | Lanier Office Equipment & Supplies
Service code 561 error
May 15, 2009 | Lanier Office Equipment & Supplies
Dark copies with overprinting
Cleaned the coronas as per instruction book. Done this before but this time it made a difference.
May 07, 2009 | Lanier 1205 Copier
Power problem code sc552 lanier
What is the error code? Many of the codes refer to a general electrical problem, and often turning the machine off, resetting the circuit board connectors and harnesses and memory sticks, and turning the machine back on will clear the error code and allow the machine to boot up normally.
Oct 27, 2008 | Lanier 1205 Copier
Lanier 6735 Copier
Sounds like you need a new cleaning blade. It is located inside the process assy behind the drum.
Aug 10, 2007 | Lanier 1205 Copier
66 people viewed this question
Top Lanier Office Equipment & Supplies Experts
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
