Question about Measuring Tools & Sensors
My 6yo NatGeo super weather station has quit transmitting outdoor temp & humidity info. The display is present and correct for all other categories. Changed batteries, no help. Any ideas?
Posted by maggiedonato on
Tom Chichester
    Top Expert:
  • Measuring To... Master
  • 57,312 Answers
  • Remove all batteries
  • Install batteries in transmitter and wait for it to begin sending data
  • Install batteries in receiver. You should see temperature and humidity displayed
Posted on Jul 19, 2017
  • maggiedonato Jul 19, 2017
    Excellent! It worked perfectly, and I thank you sincerely, Master Chichester.
    Maggie
5 Related Answers
simpson2nd
  • 59 Answers
SOURCE: Weather station giving wrong outdoor temperature all of a sudden
check if you have the US standard or international standard, like FD. or CD...........
and check your pda the loation where you set is right.
and try to reset a new website for your PDA weather software for updating. becasue different websites may be vary
Posted on Jan 10, 2009
Anonymous
  • 3 Answers
SOURCE: 3M Precision Digital Atomic Wall
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Posted on Jan 15, 2009
kb8dns
Rod Wallberg
  • 494 Answers
SOURCE: dashes in my outdoor weather reading of Oregon Scientific station
The signals are not being received by the main unit. Try to reposition the unit or move it to a different location. Also make sure the antenna is in the clear and not next to any thing like a cordess phone or charger as these can make RF noise that can block or cover the needed signals.
Posted on Feb 11, 2010
Anonymous
SOURCE: atech weather station with
First thing to do is remove all batteries. After you do that, insert the new batteries into your receiver unit. After a few seconds, insert the batteries into first sensor (-> ch 1) After first sensor has connected (beep from receiver) insert the batteries into second sensor. Click on the link below to access the user manual for the WS303G
http://www.atech.hk/
Posted on Oct 19, 2010
Anonymous
  • 17 Answers
SOURCE: My AcuRite 00992 wireless weather
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed.
Posted on Oct 21, 2010
I have an Acurite weather station, model 02080, and when I place the lightning sensor outdoors as it states in setup, outdoor temp is indicated. How do I set it up to work properly?
The display has the internal sensor for temp and barometer, The 5 in one has the sensor for outdoors and shows temp, wind speed and direction, humidity and rain. With the added lightning detector having the additional temp sensor in it, the system is redundant. It is recommended to put the sensor outside for best results that t have the least interference and maximum range..
Apr 01, 2018 | Measuring Tools & Sensors
I have the Atomic Clock model W86111. I had to change the batteries on the outside device. The clock outside temp just flashes 63.5 all the time. How do I make it sync to the device outside?
Remove all batteries from outdoor sensor and weather station.
Press one of the buttons on the weather station at least 20 times to clear all memory.
Verify that the weather station is blank before proceeding (there may be lines painted on
the screen that will show when power is removed).
Leave both units without power for 15 minutes (very important).
Insert fresh batteries into the clock.
Insert fresh batteries into the outdoor sensor.
Press the TX button on the outdoor sensor to transmit RF signal.
Keep the outdoor sensor 5-10 feet from the forecast station.
When RF connection is established, the temperature will appear on the station. Allow the
outdoor sensor and weather station to sit together for 15 minutes to establish a strong
connection.
Oct 14, 2017 | Home
Just put new batteries in both units but can't get the oudoor temp to show - what have ee done wrong?
Replacement has to be done in a certain order.
  • Install batteries in outdoor unit. Allow time for unit to initialize and begin transmitting temp.
  • Install batteries in indoor unit. You should see outdoor temperature displayed.
You may find that the outdoor temperature is not transmitted in very cold weather. Right now it is below freezing and my indoor unit is showing - - for outdoor temperature.
Dec 13, 2016 | Measuring Tools & Sensors
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
Dec 16, 2015 | Audio Players & Recorders
Why is outdoor temp blank?
The trick with these devices is to install batteries in the transmitter first, then wait for a time until it begins transmitting before installing batteries in the indoor unit.
Sep 17, 2015 | Measuring Tools & Sensors
Will not transmit outdoor info. Batteries good- LED lights. Monitor shows indoor temp only.
There are a couple of possibilities for the failure to transmit/receive outdoor data. First, resynch the two units. This will depend on the manufacturer. For some brands, you need to take the batteries out of both the indoor and outdoor units for 10 minutes. Then put the batteries into the devices with both side by side (working inside is easier). Wait until the outdoor data is displayed. There are some weather station systems where the outdoor unit isn't weather-proof. You may need to dry the outdoor unit for several days after removing the batteries before resynching it to indoor sensor.
If the data displays properly when the outdoor unit is inside, you may have the outdoor sensor too far away from the indoor unit. (The distance will depend on the number of walls and the composition of the wall studs/siding.) Try keeping the two units closer together.
If the outdoor data isn't displayed when the two units are side by side and the reset procedure doesn't work. One device has an internal malfunction (transmitter or receiver failed). It's probably best to replace the unit. If it is under warranty, contact the manufacturer.
I hope this helps. For specific details on resetting the indoor and outdoor units to synch them, please add a comment with the make/model of your weather station.
(I've seen Davis Weather stations damaged by a close lightning strike. The outdoor unit had to be replaced.)
May 23, 2015 | Measuring Tools & Sensors
My weather station is no longer recieving an outdoor temperature reading. The barometer is working fine, as is the indoor base station. Both were given new batteries at the same time, and the set up i
hi,
does the outside humidity working ?
if yes - the outside station is transmitting but the temperature sensor is faulty,
if no sensing is available from the outside station, it look like the outside station is faulty . (this is common because of extreme weather change.
notice that the pressure sense is done in the base station.
regards ,
Daniel
https://www.rylwy.com/
Nov 23, 2017 | Measuring Tools & Sensors
WEATHER STATION AC100MB stops transmitting outdoor temp
I have experienced the same with numerous different, "quote un quote" atomic clocks! Please don't forget that this sender unit, that goes outside, generates a RF Singal to be received by the clock inside. This unit transmits a signal 433 MHz signal approximately every. 3 minutes, and after so many years the sender unit's RF section(electronics) just goes out or no longer function properly or not at all! The transmitter/sender for this model number, according to "3M" is obsolete and can no longer be furnished, DRATTS !!!!!
Mar 20, 2012 | 3M Measuring Tools & Sensors
BIOS Digital Wireless Thermometer 312BC SETUP INSTRUCTIONS
I have a BIOS wireless indoor/outdoor thermometer. The indoor base unit doesn't display the outdoor temperature - it is blank - however the other temperatures - humidity, indoor temp, etc., are displayed, What is the problem? We have misplaced the manual so we don't know what to do.
Aug 28, 2010 | Measuring Tools & Sensors
My AcuRite 00992 wireless weather station has suddenly quite displaying the outside humidity and dew point. Batteries are all new. I have lost my manual to troubleshoot this problem.
Aug 27, 2010 | Acu-Rite Adagio Clock Radio
Measuring Tools & Sensors Logo
587 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
