SOURCE: In the Card/Battery compartment, there is a tiny
if you feel technically inclined you can open the camera carefully and take it apart to the point where you can remove the upper circuit board ( NOTE 1: make a careful note of every screw you remove since they are different size and need to be used exactly in the same order) and then the small black plastic assembly above the circuit board below, you can see the defective switch on top of the 2nd board, remove the plastic part of the switch until you see the bare 2 contacts on the circuit board, solder a small piece of wire to bridge the contacts, now very carefully reassemble the camera observing the exact order of screws used, see NOTE 1. If everything is back in order insert the battery and the camera should work now.
note: should you not be inclined to do this work and want to sell the camera as is for spare parts I am interested, drop me a note at: cocnutray at yahoo.com. A Nikon repair shop will charge between $80 to $110 FOR THIS TYPE OF REPAIR, THEY WILL ACTUALLY REPLACE THE DEFECTIVE MICRO-SWITCH. HOPE THIS HELPS :-)
