SOURCE: Black lines on scanned copies
Try this. Lift the lid to expose the top glass. To the left of the main glass panel, you will see a narrow glass strip. Clean this strip using a soft cloth or sponge moistened with a nonabrasive glass cleaner, then dry it off with a dry chaois cloth or cellulose sponge. A.
SOURCE: black line when scanning though auto feeder
pls clean the side glas of scnner with tissue paper ther is two type of glass is there one is a4 size and second is normal slim one so pls clean the slim one with wet tissue paper and see is ti clean .
bye
SOURCE: Line in the scaned pages
Morgansaki,
You have a dirty scanner lense. when you lift the top cover, as though you were going to do a copy from the platten glass, you will see there is a smaller glass to the left hand side of the scanner. look very hard at this glass and you will see there is a dirty mark on the lense. clean the cglass thoroughly with some quality window cleaner and you will find you line will go away.
Gremlin11
SOURCE: thick black line through page when copying or scanning
Sounds like part of your scanner is not functioning and reading black all the time. Probably best to return it for a replacement.
Steve
SOURCE: Vertical lines in copies and scanning
You need to clean small exposure glass located on the left of the main exposure glass.If this doesn't help,it can be a dust under the glass or on the mirrors that causing lines.
