Pressure cookers these days are pretty much foolproof. You generally use a small amount of water in the cooker, put in the food to be cooked, attach the lid firmly, turn up the heat until steam escapes the pressure valve, reduce heat so a small amount escapes, cook until done. Cooking time is greatly reduced in a pressure cooker because the vapor pressure above the water makes the water boil at a temperature higher than the usual 212 degrees Fahrenheit .
You can do an internet search for pressure cookers in general, or yours in particular. You didn't mention if yours is stove top or plug-in. You should search for the type yours is.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
SOURCE: I need the manual or instructions
try calling 1-800-233-9054 and ask for customer service. or try googleing part no# "p/n 60658" it is the part no# for the 8 quart manual thats in pdf form and 20papges long ,it should be about the same .
[email protected]
SOURCE: Need pressure cooker manual
The pressure cooker is make by Denmark PC, you can download a manual from
http://www.tabletopsunltd.com/en/main.html#use and care?id=61&cl=CL1
It's either hard anodized or polished aluminum.
Please rate this solution. Thanks.
SOURCE: Cook's Essential CEPC800 programmable pressure cooker
hello
i have a copied owners manual id be happy to email you or send in exchange for a rubber gasket for the same model. can you help me?
SOURCE: I just bought an Imusa pressure cooker at Targets. No manual
I'm not too impressed with your answer (buy a plan that will surely help
me) You didn't even address the question I asked or direct me to a
different site. Forget I asked. [email protected]
