Question about Yes Televison & Video
TV 32LK330-UB can`t turn off comes on when I plug it in ? also has a blinking box saying the channel map is empty do you want to start auto tuning yes or no. I can`t do any with the remote. ? just keeps blinking.
Posted by Edward on
2 Related Answers
Thomas Lee Miller
  • 118 Answers
SOURCE: cant tune any channels
Check and make sure you have correct input selected ( ie cable, antenna)
thanks Tom
Posted on Nov 29, 2011
sdburton
twowheelin
  • 166 Answers
SOURCE: How do I repair an LG 32LK330-Ub Auto channel tuning does not work.
If you have a cable box and your cable is attached with coax to the antenna or cable input you're probably receiving everything on Ch 3 or 4. If you don't have a cable box, then make sure the input / source is set to cable and not antenna.
Posted on Dec 03, 2014
Hi my channel list is empty please assist
You must auto tune the TV so it knows which channels it can receive and which it gets no data from. The menu should have this setting. Make sure your cable box or antenna is hooked up to the TV before you begin the auto tune. Also be aware that an antenna will no longer receive analog broadcasts due to the digital switch in 2009.
Jan 29, 2018 | Televison & Video
Toshiba rd-xv47kb auto tune
Check that you have the arial plugged in correct input otherwise it will not tune up.
May 11, 2008 | Televison & Video
My TV has just come up with dartabase empty it has been ok
the "auto tune" is worthless. Don't worry about it. If you have cable it is probably the reason it does not complete. The channels you are getting are all there is........sadly
Jun 30, 2016 | Televison & Video
Is database empty another term for no signal? I have tried factory reset and auto scan but I keep getting "database empty
Yes.
You need to do a Full Factory Reset tuning rather than just a rescan.
Rescan simply looks at the place holders where the old channels were stored and refreshes them. A Factory Reset (A.K.A. Shipping Condition) wipes the channel memories and starts again fresh.
Sep 04, 2014 | Televison & Video
Channel map empty
It may have defaulted to the wrong input when it turned back on. If you press the input button a few times it may cycle through to the one that has the channel listing.
Oct 11, 2013 | LG Televison & Video
No user manual for CE28DN9-B. Bought TVonics
HELLO
Follow these instructions:
Select a spare channel on your TV say 6 on your remote.
Press MENU.
Scroll down and select PRESET.
Using RIGHT button of F/OK/ENTER press it and this will go to TUNING.
Press RIGHT button again which will let you go to SEMI or AUTO tuning (for your purpose select "SEMI").
Scroll DOWN to highlight the actual UHF channel number or CH:C21 as it may appear on the screen.
Press the RIGHT button again yourself manually and you will see the channel number change anywhere from 21 to 69 until you come to your freeview box's RF channel output.
When you have done that scroll down to Memory and you'll see a box beside it. Press the RIGHT button and a tick will appear in the box.
You have stored your Freeview box RF channel on your TV.
Press MENU button THREE time to come out of the MENU setting.
Use this procedure again if you wish to change the RF channel on your TVONICS box.
GOOD LUCK (:-)
Oct 03, 2009 | Televison & Video
Tuner will not pick up cable box on channel 3, front and rear AV
In order for the TV to work with the cable box by using a piece of coax and tuning the TV to channel 3, you must make sure the TV is in "Cable" mode on the tuner and not "AIR or Antenna" the frequency maps are different between these types of service and channel 3 cable will not be the same as channel 3 on Air or UHF/VHF.
Often there is an auto program feature on TV's that will "scan" for all available channels, and this should select the proper input type.
Hope this helps!
Mar 29, 2009 | Philips Magnavox MS3652S 36" TV
ITD 58, 59, 60, 61
press info button on the remote then goto tuning on the blue screen menu. say yes to auto tune then save.
Jul 28, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
Auto tune
unfortunately tramission has been changed and certain boxes have an auto tune process as a loop. the box will work but you will have to deselect it everytime from time to time. i have the same problem with the same model. idt59g i believe. its down to the local argos with another 20 pounds to get a newer one im afraid.
i did try to turn off the auto tune option but have had no luck
Jul 09, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
Toshiba D-VR650KU can't "see" digital channels
On the Notification screen with Cable highlighted I found that left clicking on Cable gave a drop down menu with TV on it for selection. The manual says that while Cable is highlighted, use the up or down arrows to get TV to be an option and then select it and Yes and enter. Hope this helps. I have other problems with my monitor on Line Out, the screen oftens turns blue indicating low or no video using Line 1 or 2 inputs.
Feb 21, 2008 | Toshiba D-VR650
Televison & Video Logo
Top Yes Televison & Video Experts
Marvin
Marvin
NOEL
NOEL
ray gallant
Are you a Yes Televison and Video Expert? Answer questions, earn points and help others
