Question about Locks & Locksmithing
Rj30 keypad replacement instructions , written or video
Posted by John Mezzancello on
How to hook up power cord to salt generator
Hello, Garland -
The various CircuPool User's Guides do not have information on the wire hook ups for the control box:
http://www.circupool.com/circupool-userguides.php
Nor does the CircuPool Online Help page have that information:
http://www.circupool.com/help.php
Nor do the CircuPool Installation instructions:
http://www.circupool.com/how-to-install-a-salt-chlorine-generator.php
Therefore, I suggest you contact CircuPool directly and ask for the wire connection instructions:
http://www.circupool.com/compare-chlorine-generator-systems.php#contactForm
Note: Once you have the instructions, be sure to keep them in paper format where you can find them again easily for future seasons. :)
Best wishes.
Mar 03, 2018 | Electrical Supplies
Trying to locate free instructions to remove and replace seals in 2006 Evinrude etech 75HP
Hi Sue.
Try Boatinfo They have a wide range of manuals.
Good luck.........
Feb 29, 2016 | Boating
Written instructions for replacing thunderbolt screen
bn110 search on you tube the video to see how to do it, it will be more easy for you to do it with video.Best of Luck.
Jun 29, 2012 | HTC VERIZON DROID THUNDERBOLT ADR6400 ADR...
I need instructions to reset the code
"How can I program my electronic keypad lock when the instructions with the programming code have been lost?"
The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This number is the programming code referenced in the information for changing the entry code.
This link will take you to the page that you need to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Then scroll down to this heading on that page:
Electronic Security-Keypad Deadbolt BE365
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! Batteries should be replace about every three years.
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Sep 08, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
I CAN'T REMEMBER MY 6 DIGIT CODE AND CAN'T FIND MY MANUAL, I WANT TO RESET IT, CAN YOU PROVIDE ME WIT INSTRUCTION?
Aug 24, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Lost the instructions How do I reset the entry
Aug 20, 2011 | Schlage BE365-CAM BE365CAM505 Lifetime...
We misplaced our programming instructions and would like to know how we set up our keypad with our own code. Thanks, Susan
Reprogramming BE 365:
This link will take you to the page you need, to get started:
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
Jul 18, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
GET INSTRUCTION
Electronic Security-Keypad Deadbolt 365
Jan 06, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Keypads
Yes, both the external keypad and the PCB assembly are relaceable. Here is one that I found online for $59 and change. http://www.cellulardr.com/0171038A01.htm . If you visit some other online resources you may find an instructional video on how to replace the PCB assembly and the tools required. Hope that helps.
Oct 28, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Locks & Locksmithing Logo
365 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
