Question about Vtech Lands Phones
Bought a used vtech 5.8 phone, charged the battery and now see message "not registered. I can not make calls... how do I register it?
Posted by Cristina Vegas on
  • Cristina Vegas
    Cristina Vegas Jul 17, 2017
    Thank you! Your instructions worked perfectly! I will keep you in my "speed dial"! :)
  • Cristina Vegas
    Yes and it works fine now. Thanks.
Andrew Taylor
    Top Expert:
  • Vtech Master
  • 33,991 Answers
I believe it is telling you it is not registered with the Base Unit. You did get the Base Unit with it didn't you, otherwise you have a paperweight.
If you do have a set then this is the answer
Tip 1 of 1
Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger.
Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while, the handset will emit a series of tones, and the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
https://vt.vtp-media.com/ecp/documents/product_Product/67/UserManual/1647/ia5874_manual_bkm.pdf
Search Results
VTech 5.8GHz Cordless Home Telephones & Handsets ' eBay
https://www.ebay.ca > ... > VTech 5.8GHz Cordless Home Telephones & Handsets Results 1 - 25 of 151 - This is a Vtech 5.8 cordless phone digital answering machine base with time stamp & a handset that needs a new battery. It came from an ...
Technical Product Support ' VTech® Cordless Phones
https://www.vtechphones.com/support/technical-support Stay up-to-date on new VTech products, emerging technology and special offers. ... My VTech DS6722-3 Cordless Phone rings once and then disconnects. Why ...
Vtech 5.8 Phone Instructions ' Techwalla.com
https://www.techwalla.com/articles/vtech-58-phone-instructions Mar 31, 2015 - The Vtech 5.8 is a cordless phone that allows you to add additional handsets to your main phone so that you can have quick access to phones ...
[PDF]User's manual - VTech Canada
www.vtechcanada.com/support_docs/vtt/CS/CS5111-x_en_cib.pdf everything new at VTech, visit our website at www.vtechphones.com. ..... Once you have initiated your call by dialing the phone number in pulse (rotary), press.
[PDF]User's Manual
https://vt.vtp-media.com/ecp/documents/product.../67/.../ia5874_manual_bkm.pdf and operate your new VTech phone . Please take the ... Enhanced 5.8GHz Technology - Dual band transmission combines the best of 5 .8GHz and 900MHz ...
Video as well in link
vtech 5 8 phone Google Search
Posted on Jul 17, 2017
Testimonial: "Thanks! You are the best!"
  • 1 more comment
  • Andrew Taylor
    Andrew Taylor Jul 17, 2017
    curiosity, do you have a base unit and others satellite units?
  • Cristina Vegas
    Yes, and it is working now. Thanks for your interest.
  • Andrew Taylor
    Great. I am pleased. Thanks for the feedback. ??
5 Related Answers
Anonymous
SOURCE: Not Registered
I had the same problem and this procedure fixes it! First, unplug the power to the main base (answering machine) for 20 seconds. Plus it back in. Put the phone that says "not registered" in the main answering machine. It will say "press the find handset for 4 seconds". Do that. It will run thru a series of stuff and will find the handset. It works! Rich (jambones.com)
Posted on Jun 01, 2007
Anonymous
  • 3 Answers
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Posted on Apr 26, 2009
Anonymous
SOURCE: Not Registered Problem
This worked for the 7100, hopefully it works for other models:
When the handset says "not registered", it should still have a "menu" option. Select that, then the only choice is "register", select Ok. Now it says "searching for base", press and *hold down* the "locate handset" button on the base until the handset beeps and wakes up. Docs say this could take up to 30 seconds (it was about 17 for mine).
Posted on Jul 01, 2009
Anonymous
SOURCE: My vtech 5825 screen says NOT REGISTERED and does not work
Place the handset in the charger and press find handset for 4 seconds.This will register the handset. do the same for other handsets.
Posted on Sep 20, 2009
whynot3k
  • 4 Answers
SOURCE: How do I register and charge my Magellan GPS
In order to "register" your Mag_1440 (or any other Magellan), you need to create an account on the Magellan_GPS Web-Site. You will basically supply your name, address, tel_number, e_mail, and the model and serial_number of your GPS... Once you have created your account and registered you GPS, you may be prompted with Links for software and/or map updates... As far as "charging" the 1440/1470, you only need to plug the GPS_Unit into the Car/Auto_Cigarette outlet via the 12v power cord that came supplied in your package... One can also use any standard 120v (AC) to Mini_USB charger (i.e Motorola Razr Cell-Phone AC_Power-Pack) to charge up the GPS unit...Unfortunately, the Computer_USB to Mini_USB cable (in the box) supposedly will NOT power/charge up the GPS... This Mini_USB cable is used to download the latest firmware (v2-20) onto the GPS (approx. 75_MB)... Therefore, before you attempt to download the latest firmware onto the 1440/1445/1470, be sure that it has been sufficiently charged via the Car_Adpater, or an auxilliary AC-Power Adpater... Hope this helps...
Posted on Jan 31, 2010
I bought a base and one extension phone - no problem - bought another extension phone and it will not register
The new phone must fit into the base cradle for registering to even be attempted. You gave no model numbers, it is likely your newest handset is not compatible with the rest of your system... but we can sometimes "cheat". If the new handset is displaying "To register, place on base..." but it simply does not fit -- try removing the battery cover and see if wiggling the handset will allow the "charging" lamp to come on: then wait to see if it will register. You can find the base model number on a small sticker on the bottom of the base, the handset model numbers are on stickers under the battery.
Apr 09, 2016 | Vtech Cordless Phone Battery for 2429,...
Vtech cs6649 will not register more than one handset
The errant handsets must be de-registered from their
original base and then registered to your base.
NOTE: the CS6649 handles a maximum of only five
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
In that case, you can clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( II.) To clear the base of all handset registrations
( if needed, else skip ahead to ( III ). )
1. press [Find Handset] on the base and hold
past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink. 2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration ===============================
( III.) To register each handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
Good luck !!
Jan 09, 2015 | Vtech Lands Phones
How do I register my vtech phone?
"Register" refers to the pairing of the handset to
the base so they can communicate securely
in private via an encryption scheme so no one
can easily evesdrop.
When you first set the phone up for use, you will
need to effect the registration then:
Good luck !!
Jan 03, 2015 | Vtech CS6829-26 2 Handset Answering System...
How do I register a cs6114 phone
Do you need to register a handset? Make sure the battery is fully charged on the handset and remove the handset from the base. With the phone not in use, press and hold the Find Handset button on the base. After about 4 seconds, the In Use light should light up. Now press the # key on the handset that you need to register. It should say Registering and then complete the registration within 60 seconds. This will only work if the base has power and is connected to a working phone line.
If you need to register the phone with Vtech, go to http://www.vtechphones.com/support/general/product-registration .
I hope this helps.
Nov 17, 2014 | Vtech 5.8GHz Analog Cordless Phone
How to activate a vtech phone
Instructions
    • 1Remove the battery cover from the back of the phone. Most models have a door that slides downward to reveal the battery compartment.
    • 2 Install the battery by inserting the connector on the battery wires over the pins in the handset battery compartment. The connector will only go on one way.
    • 3 Insert the battery pack into the compartment and replace the battery cover.
    • 4 Charge the phone by sitting it in the charger for a minimum of 16 hours on the first charge.
    • 5 Place the fully-charged phone onto the cradle of the base unit and wait for the display to show "PRESS FIND HNDST 4 SEC ON BASE." If the message does not come up, lift the phone off the base and put it back in the cradle.
    • 6 Press and hold the "FIND HANDSET" button on the base unit for approximately four seconds. The display on the phone will change to "PLEASE WAIT," then "HANDSET X REGISTERED."
    • 7 Test the phone by making a call.
Jul 14, 2014 | Vtech Lands Phones
Vtech cordless handset CS6209 will not connect with CS6229-2 base
Yes. The'old' handset must be de-registered from its
NOTE: the CS6229 handles a maximum of 5
You will need to clear each handset ( I ) then clear
1. press [menu]
press [select]
replace the cover
Good luck !! --
Jun 08, 2013 | Vtech Lands Phones
I cannot get my Vtech LS6204 to register. I have tried everything and the screen always reads registration failed.
I have a 2-handset VTech CS6419 that I had been using w/o problems for months. Both HS were always plugged in and charged. One day I found the base HS would not ring and the screen had the message that I needed to register the HS. Pressing the "find HS" button to start the process only made the accessory HS, not the malfunctioning base one, ring. I solved the problem by 1) unplugging the base, 2) pulling the batteries from BOTH handsets, then 3) replugging in the base and reattaching the battery for ONLY the malfunctioning HS. 4) I then did the registration process again (press the "Find HS" button on the base for 4 seconds, then press the # button on the HS and wait.) The malfunctioning HS then registered! I then reattached the battery to the accessory HS and returned it to its' base. Problem solved!
Jan 01, 2011 | Vtech LS6204 1.9 GHz 1-Line Cordless...
May 16, 2008 | Vtech IA 5845 Dual Handset Cordless Phone...
Not Registered
Feb 03, 2007 | Vtech IP5825 Cordless Phone
I had the same problem and I JUST fixed it! First, unplug the power to the main base (answering machine) for 20 seconds. Plus it back in. Put the phone that says "not registered" in the main answering machine. It will say "press the find handset for 4 seconds". Do that. It will run thru a series of stuff and will find the handset. It works! Rich (jambones.com)
Dec 25, 2006 | Vtech IP5825 Cordless Phone
Lands Phones Logo
272 people viewed this question
Top Vtech Lands Phones Experts
Marvin
Marvin
Bruce Robin
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
