Question about Lexmark Office Equipment & Supplies
How do I reset a lexmark ms312dn that has a lot of weird letters as error codes
200.20 lexmark x340
My solution: I am in Europe, where we use A4 paper format. If the printer is set to Letter format, it will give this error. Go in menu and set the A4 insteed Letter. I found this simple solution after I dissansambled all printer and check paper path and sensors :)))
Jul 30, 2012 | Lexmark X340n All-In-One Laser Printer
Describe your X2690 All-In-One InkJet Printer Problem how do you reset the print cartridge
Why do you want to reset it? For not using original Lexmark Cartridges? A lot of the newer printers will not work with compatible cartridges, regardsless of what the sellers of such cartridges tells you. You might want to try the following:
Power off the printer.
Hold the cancel (red) button in while powering on. Keep the cancel button in for atleast 10 seconds. On some Lexmark printers this will reset the cartridge error, but it does not work on all Lexmarks
Aug 23, 2011 | Lexmark X2690 All-In-One InkJet Printer
Get the error message change tray to plain letter
Most probably the paper tray guide is not set properly. Here's a link to the Lexmark website to guide you on what to do when having an error like this. Just click on this link: http://bit.ly/c4AO17 . You can move the paper tray guide back and forth and setting it to the correct size.
Apr 08, 2010 | Lexmark Optra T610 Laser Printer
Problem with printer error # 1203
Unplug your device and replug it after sometime. Now run Reginout scan and reset your machine. Hope it would help you. Thanks
Dec 13, 2009 | Lexmark X2500 All-In-One Printer
My printer lexmark e352 shows an error code 84 replace fotoconductor unit. How to reset this error code
The above error code refers to :-
The Transfer drum has reached the end of it's life and must be replaced. May require service technician
Press "GO" to clear message and temporarily continue
Hope i helped you.
Thanks for using "Fixya".
Jun 23, 2009 | Lexmark E352dn Laser Printer
Lexmark C510 Code error: 995 Service Engine Error
May 06, 2008 | Lexmark C510 Laser Printer
Lexmark hardwear error code 0502
Open the printer. Take a Kleenex and wipe off the metal rail the cartridges travel on. You will find a lot of ink build-up. Be sure to wipr off the ENTIRE rail. You should be good to go!
Jan 13, 2008 | Lexmark X5150 All-In-One InkJet Printer
878 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
